LG plasma 50pk550 EAY60968801
  • veikra
    • Sep 2012
    • 55
    • canada
    hi,
    I have a trouble finding the problem with the eay60968801 power supply. Problem is confirmed being from the power supply as I have fixed it before but now it's a different problem.
    First repair: IC301 3br1565 infineon chip. worked for a few days, then wouldnt start again. Everytime Id pop a new IC301 in it it would start then eventually stopped
    then it wouldnt come back on, acted just like the first time. clickon on then off and red led slowly dim. Then it retries.
    BUT I took it hook to bench test it, and now it has a different clicking. Now only 1 repair clicks, and it's a more rapid clicking. click click pause click click but all on the same relay. the second relay beside it doesnt click at all.
    the 164V point near ic301 drops when the relay clicks on, and standby plummets
    I have replaced these so far :
    IC701,IC301,IC601,IC801
    D602,D603,D304
    Q601,Q602,Q801,Q802
    R927,R929,R607,R613,R934,R305
    fuses are good,
    I previously saw a post where someone had drawn up the schematics, but didnt find them this time.
    I could use some help <.<
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG plasma 50pk550 EAY60968801
    What is your voltage across main caps on primary side of supply? Sounds like a low voltage feedback circuit problem.
    • veikra
      • Sep 2012
      • 55
      • canada
      130v to 160V across the 3 big caps that are laying down on the primary side
      • freakaftr8
        • Oct 2012
        • 3743
        Ok how hot is it regulator getting as the TV was running? Also what is your voltage to the VCC pin on that Infineon regulator?
        Also pin 8 on output to mainboard is Error detect. Getting any voltage there? In standby voltage should be 2.85v and in operation should be more like 4v
        • veikra
          • Sep 2012
          • 55
          • canada
          the 3BR chip doesnt heat up .
          And considering the vcc of it varies from 3 to 9V in time with Rl 101 clicking...I dont think it's booting up at all.
          BUT we may be in the right direction, the D303 diode is warming up 5C over ambient, and in circuit mesure a dead short circuit.
          I'll take it out and check it
          • veikra
            • Sep 2012
            • 55
            • canada
            diode D303 is good out of circuit, so something connected to it is shorted
            • veikra
              • Sep 2012
              • 55
              • canada
              sorry missed that last part. Pin 8 on the header, error detect is 0V.
              I have neither a standby or on, it's constantly switching on and off.
              Anyone has IC701 datasheet?
              • veikra
                • Sep 2012
                • 55
                • canada
                The transformer's coil connected to D303 is 0.4ohm , hence why I thought I had a short. Disconnecting it doesnt change anything
                • veikra
                  • Sep 2012
                  • 55
                  • canada
                  3BR1065 chip supply is now 12-15vdc between VCC and GROUND
                  It should be able to boot, but no 164V at F302 still.
                  I knocked off and lost c101 near ic701. But it seems related to in-circuit programming so I dont think it's my issue. I put a random salvage on.
                  I started drawing the schematic, out of ideas
                  • veikra
                    • Sep 2012
                    • 55
                    • canada
                    I found the schematics here https://drive.google.com/file/d/0Bzv...N6d1RKS1k/view
                    From what I can see, I get 5v for a little while then error detect on the header. I think there is 2 source of 5v, the second not working and the voltage drops. 130V 160V on the PFC OUT point of the schematic.
                    • tw2005
                      • Oct 2011
                      • 6458
                      Have you gone over this real closely and resoldered all the cracked joints?
                      Just repaired two of these both had broken solders and lots of them. Was definitely the fault.
                      • veikra
                        • Sep 2012
                        • 55
                        • canada
                        yes, I did go over it on all the major components. I dont have a microscope though!
                        What were your symptoms? I have Rl101 clicking on and off and no stable 5v standby
                        • tw2005
                          • Oct 2011
                          • 6458
                          Without measurements. I would say it had stdby. Red light then relay latch white light then immediately relay unlatch back to standby. Did not have repeatedly clicking
                          • veikra
                            • Sep 2012
                            • 55
                            • canada
                            microcontoller m81f4316 gets 5v, turns on relay rl101. That I know.
                            From my understanding, the relay sends power to the emiter of opto PC102 which activate the transistor side. So m81f4316 should get 4.5V on r03 (pins 28 ) when rl101 is activated.
                            Is that correct? Because I get nothing on that pin 0V
                            • tw2005
                              • Oct 2011
                              • 6458
                              Just got another one of these, my be closer to the issue you.
                              So this one. stdby 3.4V ,but at RUN= 5.1 v . 17v was present, no Va or Vs
                              Relays just clicking.
                              Resistors good, check all solders and reflowed. Nothing shorted,
                              Swapped out all main Ic's from good board, - no change
                              Started swapping optos, no change..................until I changed PC101,102. Can't say which one but now it's running.
                              Funny thing I started with an opto swap , just the wrong one based on a mention somewhere in another thread.
                              They're nothing special real common garden variety opto you see a lot. chances are if you have some boards laying around you'll have something
                              • tw2005
                                • Oct 2011
                                • 6458
                                Not sure what happened but I remembered I swapped 2 FETS from another which were 3Amps less. put the 15A ones back in brushed up a couple of spots and a clean. Farking thing, back to clicking but only does 3 or cycles then quits.
                                Over it TBH.
                                Tried reversing back to where it was working, nup. Stuff it.
                                • veikra
                                  • Sep 2012
                                  • 55
                                  • canada
                                  my this could be the optos ! I had some weird mesures with them but shrugged it off when remesured them correctly later... Definitely something Ill try and scavenge on other boards.
                                  the 3 cycles then stop was my previous problem, and was a bad infineon 3br chip not booting right. I have bought many, and the first I replaced was a dud. Can't find them on digikey, only on shady ebay sellers.
                                  I have a bunch of good working ones .
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Pretty sure the #br chip I have is in fact one out of a working board, could try swapping back I guess. I generally don't touch power supplies and without proper fault finding I am shooting in the dark,
                                    • veikra
                                      • Sep 2012
                                      • 55
                                      • canada
                                      im concentrating on the microchip. It's not getting feedback from the first relay clicking on. Did you download the schematics I linked?
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Yeah , that's by paulstef. generally I take good guesses but this has been tough. Not a great fan of powering it up and probing. I have a tendancy to get the jitters and short stuff.
                                        It also appears the micro is programmed too.
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
                                        • edugimeno
                                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                          by edugimeno
                                          Hi everyone!
                                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                          I respected the polarity, positive to cathode of protecting diode
                                          So provided all...
                                          04-18-2024, 01:15 PM
                                        • jimbofz
                                          samsung plasma ps50 c580g1k slow tripping relay
                                          by jimbofz
                                          Hi ,this appears to have 2 faults
                                          black lines on raster and faulty main board ?
                                          let me explain futher
                                          at switch on the relay does a few slow clicks with red led blinking and repeats every 10 seconds .i ran the psu into 2x 100w lamps and it runs fine all day supplies good .
                                          i removed y sus and x sus checked for dry joints and checked all igbt anf fets all ok
                                          next i removed buffer and checked for any s/c buffer ics all ok
                                          so i unplugged feed to main board from logic board and linked test points pin 3 and 4 ,
                                          tv still trips but now i get plain...
                                          03-15-2021, 02:18 AM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
