LG plasma 50pk550 EAY60968801
  • tw2005
    • Oct 2011
    • 6458
    Re: LG plasma 50pk550 EAY60968801
    No change but just got my 60" going, EAY60968901.
    • tw2005
      • Oct 2011
      • 6458
      LOL, Maybe not
      • tw2005
        • Oct 2011
        • 6458
        When you get rapid clicking, check zd301 for short, 17V will also be missing. Sits around ic301.
        • tw2005
          • Oct 2011
          • 6458
          Still wasting my life on this one but I've forced everything on at P813, end result is the same as in the TV except instead of quitting after 3 powerup cycles, it continues so the mainboard must quit powering up , 3 strikes, you're out.
          it has
          Stdby 3.4 - 5v on run
          M17V is present, M5V is on, Err Det (not used) is 4.9V, AC DET is also Ok 4.9V
          VA, VS zippity do dah
          I've swapped L6599D, R2A02117 and the micro all from a good board , no change
          I've managed to spike and kill ZD301 several times now probing the optos, that kils the 17V around IC301 and rapid endless cliking.
          I've confirmed the micro off the bad board is ok as the good board runs just fine using it.
          Oh and the 60" is running fine, no idea but ever since I jumpered that one and forced it on, it's been fine, WTF, bad caps?
          • heavymachines
            • Mar 2011
            • 1028
            You forced it on and all of sudden tv works fine? if so weird indeed i had a samsung 21' monitor do something similar except when i replaced caps on it and a pair of fets it wouldn't work so while it was plugged in and turned on i started to wiggle components caps, and connectors and no go...... so more wiggling then on inverter i wiggled a cap all of sudden it made a spark arc sound and it worked flawlessly ever since. just little touch up on the joint and all was well even though the joint looked ok. weird
            • veikra
              • Sep 2012
              • 55
              • canada
              #26
              ZD301 seems shorted in circuit, Ill pull it and check whenever I get time tonight
              Have the part number handy?
              • tw2005
                • Oct 2011
                • 6458
                It's a 30V zener. I've used 1N4751 which is likely a higher wattage. Got several because it seems easily spiked when I poke around one of the optos.
                • tw2005
                  • Oct 2011
                  • 6458
                  Yeah, hard to trust this POS. Great picture though plus this one has had the mainboard replaced with a measly 260 hrs so with a new PSU could get 5-7 years from it
                  • veikra
                    • Sep 2012
                    • 55
                    • canada
                    #29
                    Ordered new diodes, will post results tuesday or wednesday when I get them
                    • veikra
                      • Sep 2012
                      • 55
                      • canada
                      #30
                      I replaced zd301 and it solved the rapid clicking.
                      Now I get the normal slow click and retry. click click red light dims slowly as it shut off both relays. The normal problem you know.
                      EXCEPT : I THINK this is mainboard related. Why? Because I can instantly start the tv if I probe the 5.1 rail at the mainboard connector relative to chassis ground.
                      I bet I could put a 10Meg resistor and it would work flawlessly
                      Something to think about
                      • veikra
                        • Sep 2012
                        • 55
                        • canada
                        #31
                        sorted itself out after a few power cycle. Been booting up and working perfectly.
                        Whats the service menu button combo? I'd like to check the hours. It's very very nice, could be low hours.
                        tw2005: I owe you at least a few fosters for your help j/k, Ill get you some real beer!
                        • tw2005
                          • Oct 2011
                          • 6458
                          Fosters? I can feel a XXXX coming on,
                          https://www.youtube.com/watch?v=RMRy8bjdohs
                          https://www.youtube.com/watch?v=GniEAoEHG_c
                          https://www.youtube.com/watch?v=PcDuU-C5I0w
                          https://www.youtube.com/watch?v=vAB0SGh6q18
                          https://www.youtube.com/watch?v=0yM9xD6RQj8
                          • hartonoh
                            • Apr 2020
                            • Indonesia
                            #33
                            Dear all, finally I found the culprit of cycling relay. I have checked and change all the high esr elcap and still clicking. I found that there is a bad joint in the T901 transformer. After resoldering the joints its back to live
                            • aaronwt6
                              • Apr 2013
                              • 855
                              • US
                              #34
                              I know this is a really old thread but thanks hartonoh for this post. Everything discussed her previously checked out on a power supply I have here and this put me in the right direction. I'd already inspected for cracked joints and overlooked one on one loan leg for T901.
                              • CoinCoin88
                                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                by CoinCoin88
                                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                09-15-2025, 03:36 AM
                              • jm1234
                                9V relay temperature 40C
                                by jm1234
                                Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                05-09-2024, 03:03 AM
                              • edugimeno
                                Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                by edugimeno
                                Hi everyone!
                                I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                I respected the polarity, positive to cathode of protecting diode
                                So provided all...
                                04-18-2024, 01:15 PM
                              • jimbofz
                                samsung plasma ps50 c580g1k slow tripping relay
                                by jimbofz
                                Hi ,this appears to have 2 faults
                                black lines on raster and faulty main board ?
                                let me explain futher
                                at switch on the relay does a few slow clicks with red led blinking and repeats every 10 seconds .i ran the psu into 2x 100w lamps and it runs fine all day supplies good .
                                i removed y sus and x sus checked for dry joints and checked all igbt anf fets all ok
                                next i removed buffer and checked for any s/c buffer ics all ok
                                so i unplugged feed to main board from logic board and linked test points pin 3 and 4 ,
                                tv still trips but now i get plain...
                                03-15-2021, 02:18 AM
                                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                Found shorted diodes on main controller relays there are 3 of them that...
                                01-07-2023, 05:43 PM
