Jump broken led diode
    Hi guys,
    I have a un46d6003..With 2 burned out led diodes.. Is there any way I can just solder a wire to neg and pos to close the circuit????
    Re: Jump broken led diode
    Not advised each led you eliminate increases the load on the rest of the leds causing more failures.
      I bunch of led strips salvage from tvs.. How do i find out which ones are compatible with mine?
        You will need to apply a voltage across good one and see what voltage they are. Might want to watch video may help. https://www.youtube.com/watch?v=8otPjsN8jD8&t=548s
