sharp 50-lb371u leds problems
  • robert phelps
    • Dec 2016
    • 94
    • usa
    hello, i have a sharp lc-50lb371u set thats has bad leds backlights. the first time i took the set apart i replaced 2 leds that were bad. the set worked good until i put it back togerther and then it only worked for about 10 minutes. i replaced the leds with some from another strip i had. took the set back apart and found 3 leds out this time. replaced with same ones i had. set worked for about 15 hours being on and then the bottom led strips were a little dimmer then the top ones. this set has 6 strips of leds, the top 4 are on led1 off the psu, the bottom 2 are off led2 off the psu. after turning the set off then back on no backlights again. i know these sets have a led problem, but what i need to know is the psu when you plug it in has no voltage on led1 or led2, when you power on the set the voltage goes to 64.8 to 95.6 then back to 64.8. i think that should be correct for this set. the problem is when you turn the set off the 64.8 voltage does not turn off. the psu still has a little hum of it working. seems like it should turn off completly. the only way to kill the 64.8 led volts once the set is turned on is to unplug it or unplug the logic board. someone plesae help, having a hard time finding led strips for this set and dont reaaly know if psu may be causeing this or logic board not shutting down psu like it should
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: sharp 50-lb371u leds problems
    Were the replacements from another strip which matched the existing led strip for the set or just a set of similar leds?
    • robert phelps
      • Dec 2016
      • 94
      • usa
      • robert phelps
        • Dec 2016
        • 94
        • usa
        Pics
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          I suspect that's your problem. Many leds look similar but can have different maximum current ratings. There are also 3V and 6V versions. You need to replace them with leds from an identical strip intended for that panel. It's highly probable that the ones you replaced them with were lower current rating and have stressed the existing ones causing further damage.
          • robert phelps
            • Dec 2016
            • 94
            • usa
            but what about the psu not killing the 64.8 volts going to the leds when the set is powered off. should it go to 0 then when turned off
            • robert phelps
              • Dec 2016
              • 94
              • usa
              im not thinking its just the leds here. the set is only 2 years old
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                If you were to read the many threads regarding led faults you will see that what you are describing fits the problem you have.
                What is the LCD panel name and number as given on the metal back?
                How many leds per strip and how many strips are there?
                  What is the spec of the replacement LED?
                  Vf and If rating are very important.
                  • robert phelps
                    • Dec 2016
                    • 94
                    • usa
                    But what about the psu not shutting down the 64.8 volts when you power the set off
                    • robert phelps
                      • Dec 2016
                      • 94
                      • usa
                      The leds I replaced worked for awhile
                        What you need to find out if the PS-ON (ON = >2 VDC (OFF = <1 Vdc) goes low when the TV is off or not.
                        Same for the BL-ON (same as O/F).
                        • robert phelps
                          • Dec 2016
                          • 94
                          • usa
                          The panel number is tpt500j1-hvn07.u. there are 6 strips 11 leds per strip. 4 strips are off led 1, 2 strips are off led 2. Both have 64.8 volts all the time
                          • robert phelps
                            • Dec 2016
                            • 94
                            • usa
                            Thanks buMD I'll try that in the morning and see what I can figure out
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              I'm surprised that they are not balanced and that Led1 & Led2 support 3 strips each.
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                Can you post a sharp photo of the bottom of the power supply to identify the led driver IC
                                • robert phelps
                                  • Dec 2016
                                  • 94
                                  • usa
                                  Here are pics of psu
                                  • attainteddragon
                                    • Apr 2013
                                    • 764
                                    • australia
                                    db needs to see picks of the under side of the ps to see the backlight circuitry.
                                    clear straight on pics, thanks.
                                    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                                    • robert phelps
                                      • Dec 2016
                                      • 94
                                      • usa
                                      the psu connector going to the logic board has 16 pins, 6 of them are 12v which is alway there on/ 2 are listed as 12v_a dont know what the underline means for these 2 pins. the ps_on , dim , and o/f are o volts when you plug the set in. when you power the set up ps_on goes to 3.34, the dim goes to 3.09 and the o/f goes to 3.32. when you power the set off the ps_on stays at 3.34v and the dim stays at 3.09 volts. the o/f does go to 0volts. meanwhile the led1 and led2 also stay at 64.8 volts any ideas of what could be going on. i have read these set are bad on leds but maybe its not the leds fault , maybe logic is keeping psu on all the time killing them
                                        http://www.shopjimmy.com/sharp-pltve...c-50lb370u.htm
                                        Sharp PLTVEY701XAL5 Power Supply / LED Board for LC-50LB370U
                                        Your board is XAL4, but this one looks to be the same as yours.
                                        Pictures provided by shopjimmy.
                                        • edugimeno
                                          About replacing individual LEDS on BL strips
                                          by edugimeno
                                          Hi There!
                                          Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
                                          At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
                                          How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I...
                                          11-07-2022, 11:12 AM
                                        • Kingfreddie
                                          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                                          by Kingfreddie
                                          Ok.. this is the story:
                                          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                                          This is kinda how it looked, just that mine were at the bottom of the screen:
                                          09-11-2021, 01:57 AM
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
                                        • lmcancu
                                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                                          by lmcancu
                                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                                          Instead of putting it back together I decided to replace...
                                          04-01-2023, 01:11 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
