Panasonic NV-DV2000ec
  • tehmatix
    • Nov 2012
    • 174
    Hi forum,
    I have this device with error in service mode 3 17 03, which is mean
    ''S-Reel Lock'' ''S-Reel Lock has been detected during normal rotation'' ,
    S-Reel = SUPPLY REEL.
    ''2.2.3. Self- Diagnosis Mode
    This VTR has a Self-Diagnosis function, which detects troubles when undesirable condition occurred.When one of the following listed trouble is detected,
    Power is automatically turns off and its error is saved as the "Error-Code" in Timer microprocessor (IC7501).''
    Also don't work ''Rev'' and ''FF''. The tape is ok.
  • tehmatix
    • Nov 2012
    • 174
    Re: Panasonic NV-DV2000ec
    Hi forum,
    It was a mechanical issue.Pinch arm unit lock , very hard to move it. I cleaned all the dirty grease on the shaft and everything is working normally without any error : play/pause stop rev/ff.
    • EvazX
      ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
      by EvazX
      I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
      Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
      For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
      However, after some time, the replacement motherboard...
      08-25-2025, 06:09 PM
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
      11-20-2024, 08:52 PM
    • AquaMan Ua
      by AquaMan Ua
      05-17-2025, 09:40 AM
    • spacez
      XPS 15 9520 - tpm device is not detected - NO ssd detected
      by spacez
      I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
      Service Tag: J2MSHW3
      |Express Service Code: 41518077843
      mother board LA-L402P REV 1.0(A00)​...
      08-18-2024, 10:54 PM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
