Panasonic NV-DV2000ec
  • tehmatix
    • Nov 2012
    • 180
    Hi forum,
    I have this device with error in service mode 3 17 03, which is mean
    ''S-Reel Lock'' ''S-Reel Lock has been detected during normal rotation'' ,
    S-Reel = SUPPLY REEL.
    ''2.2.3. Self- Diagnosis Mode
    This VTR has a Self-Diagnosis function, which detects troubles when undesirable condition occurred.When one of the following listed trouble is detected,
    Power is automatically turns off and its error is saved as the "Error-Code" in Timer microprocessor (IC7501).''
    Also don't work ''Rev'' and ''FF''. The tape is ok.
  • tehmatix
    • Nov 2012
    • 180
    Re: Panasonic NV-DV2000ec
    Hi forum,
    It was a mechanical issue.Pinch arm unit lock , very hard to move it. I cleaned all the dirty grease on the shaft and everything is working normally without any error : play/pause stop rev/ff.
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • EvazX
      ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
      by EvazX
      I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
      Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
      For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
      However, after some time, the replacement motherboard...
      08-25-2025, 06:09 PM
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
      11-20-2024, 08:52 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • spacez
      XPS 15 9520 - tpm device is not detected - NO ssd detected
      by spacez
      I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
      Service Tag: J2MSHW3
      |Express Service Code: 41518077843
      mother board LA-L402P REV 1.0(A00)​...
      08-18-2024, 10:54 PM
