Samsung PS51D535 Plasma - Clicking - Impossible problem
  • Hatmpatn
    • Mar 2017
    • 20
    • Sverige
    Hello! I'm having a real hazzle with my Samsung Plasma TV PS51D535.
    It clicks a few times and then stops. Screen is black.
    The wiring is as follows on the TV.
    I have tried disconnecting every board to the Power Supply.
    The clicking stops and the TV seems to boot(I have no sound on it) when I disconnect the X-SUS!
    1. I first ordered a new X-SUS board from ebay. My board is LJ41-0422A(LJ92-01759A) Rev 1.2. The board I got a hold of is LJ41-0422A(LJ92-01759A) Rev 1.3. The problem remained.
    2. I then replaced the Y-SUS, the Power supply board, the Logic board. All with matching reference numbers. The problem remained. The only board left to replace is the Main board, but it is so expensive.
    3. I got to thinking that maybe the refence difference on the X-SUS mattered or maybe a faulty X-SUS board was sent to me so I switched all the capacitors from the eBay board to my old board. The problem remained.
    This is where I'm at now. Surely the X-SUS must be my problem? What do i need to do? This is driving me crazy!!!
    The eBay board that sacrificed its capacitors. The old capacitors from the old board lies on the table while the "new"capacitors is attached to my old board.
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Samsung PS51D535 Plasma - Clicking - Impossible problem
    What are you doing
    They are not your issue
    If you have replaced x and y and power board why are you removing the caps ????
    • Hatmpatn
      • Mar 2017
      • 20
      • Sverige
      I thought that maybe the Reference difference on the board mattered so I transfered all the capacitors from the new board to the old board. But what else could it be?
      • Hamie
        • Apr 2014
        • 1383
        Yeah agree with Chris you need to take a step back here and properly diagnosed the fault first.
        Eliminate the possibility of the mainboard being faulty by jumping the power supply on, and running test patterns on the control board.
        • Hatmpatn
          • Mar 2017
          • 20
          • Sverige
          Ok, have put it all together now. No harm done. How do I go about jumping my power supply on and run test patterns?
          • Hatmpatn
            • Mar 2017
            • 20
            • Sverige
            Nevermind me. I think I know found it out by myself. I jumpered the pin 3 and 4 on the logic board and disconnected the "fine cable" running from the logic board to the mainboard. Still there is the clicking. I also tried disconnecting the power wire running from the power supply to the main board, but then there is just a dead TV. No LED on the logic board and no clicking.
            • Sevenqi
              • Jul 2011
              • 292
              Make sure you put back the cables properly seat as original.
              Take out the x and y board, check all the transistors in the x and y board looking for shorts.
              • Hamie
                • Apr 2014
                • 1383
                Jump
                ps-on to Gnd
                Vs-on to 5vstby
                • Hamie
                  • Apr 2014
                  • 1383
                  Chances are you may have bought a faulty part from eBay. But need to go through proper troubleshooting before taking parts from a board.
                  • Hatmpatn
                    • Mar 2017
                    • 20
                    • Sverige
                    Okay, I suspect so aswell. Am I now supposed to disconnect the cable leading to the logic board and the cable leading to the mainboard and jumper the PS_ON to GND on the mainboard connector on the power supply and jumper VS_ON to B5V(Cant find 5VSTBY) on the logic board connector on the power supply?
                    • Hatmpatn
                      • Mar 2017
                      • 20
                      • Sverige
                      I have taken off all the transistors from the eBay board and some really behave strangely. I have tested like this:
                      1. Put the multimeter on ohm reading, scale 2000k.
                      2. Put the negative lead on the leg to the right, seen from the front of the transistor
                      3. Put the positive lead on the middle leg. See that I get infinite Ohms.
                      4. Put the positive lead on the left leg instead and then back to middle. See that the circuit is closed(get 0ohm or something other than infinity).
                      The following transistors seems to be working(some of them doesnt show 0ohm in stage 4 but something like 800):
                      1pcs of 30G124
                      2pcs of SMK1820
                      1pcs of SMK730
                      The following transistors shows shorts in all of the stages:
                      2pcs of RJP30H1
                      2pcs of 30G124
                      Should I just replace these?
                      And what is this?
                      • Hatmpatn
                        • Mar 2017
                        • 20
                        • Sverige
                        I now tested all the "three-legged" transistors on the Y-SUS board and all are good! I didnt test the few two-legged like the picture above because I dont know what they are and how to test them. What is my next step?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          The two legged device is a 400V, 10A ULTRAFAST RECOVERY RECTIFIER
                          test it in diode mode in both directions
                          • Hatmpatn
                            • Mar 2017
                            • 20
                            • Sverige
                            And what should it show in both directions?
                            All of the rectifiers on the eBay board showed 444 in one direction and infinity ohms in the other direction.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              yes that sounds ok for them
                              • Hatmpatn
                                • Mar 2017
                                • 20
                                • Sverige
                                So what is my next step? Check all the transistors on the old X-SUS board and see if I can combine all the working transistors into a good working board?
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  Not B5V. You should use A5V and PS-ON to GND as Hamie said. Also disconnect the V-SUS cable going to the Y-SUS Bd, then connect a pair if 12Vac light bulbs in series across the V-SUS connector on the PSU Bd. The bulbs should light-up bright. If not then PSU Bd is faulty.
                                  • Hatmpatn
                                    • Mar 2017
                                    • 20
                                    • Sverige
                                    I'm not following. He said:
                                    ps-on to Gnd
                                    Vs-on to 5vstby
                                    I can't find any 5vstby. Can you draw lines in paint where I should put wires?
                                    • Hatmpatn
                                      • Mar 2017
                                      • 20
                                      • Sverige
                                      Isn't the best strategy here to focus on the X-SUS board? I has obviously been sent a faulty board with shorted transistors and the old board remains to be checked for this. Why would the PS board be faulty when the TV doesnt click anymore when all the board are connected except the X-SUS and to add to that, I have replaced the PS board.
                                      • Hatmpatn
                                        • Mar 2017
                                        • 20
                                        • Sverige
                                        Okay, I just checked my old X-SUS board and there were also transistors shorted. I took a picture and marked where I found the faulty transistors and what name they had.
                                        1pcs of RJP30H1
                                        3pcs of 30G124
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
