BGA reballing
  • syaoran123
    • Jun 2014
    • 178
    BGA reballing
    Recently I attempted to reflow a bga chip but still doesnt work. So I used higher temperatures and I think it's now messed up.
    Nevertheless, I want to give reballing a try. I have watched some youtube vids on the procedure and not sure where to start. I have seen two different methods:
    1. Using a stencil and solder paste
    2. Using a stencil and tiny balls
    Anyone have any experience? Which method do you recommend in terms of cost, time and ease?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: BGA reballing
    Stencil and leaded balls. I believe paste is suggested for Apple smc due to the tiny pad size.
    What did you use to reflow, some kind of heat gun ?
    You need bottom heat for the board and a way of controlling the top heat to resemble a heating profile.
    Depending on what you reflowed it's possible the chip was already dead. No amount of reballing will bring one back from the dead.
    • syaoran123
      • Jun 2014
      • 178
      Re: BGA reballing
      I am using a bosch PHG 630 DCE heat gun. What did you use to heat the bottom and what temp? Also there are SMD components at the bottom of the board where I wish to install the processor. Not sure if the chip is dead or not, but still keen on practising the art.
      • thoma
        • Sep 2012
        • 268
        Re: BGA reballing
        http://advancedreworks.com/forum/
        may be help!
        • syaoran123
          • Jun 2014
          • 178
          Re: BGA reballing
          Very useful link!
          • ComortleD
            • Jul 2017
            • canada
            Re: BGA reballing
            Hi
            I have faced a similar experience . My laptop had some problem and one of my friends said,it may be due to a bga reballing issue just because I used to overuse my laptop. Infact I researched on this bga reballing.
            I will prefer you bga reballing with stencils and tiny balls rather than the other. But it depends on the bga package. If you are re-balling lead-free BGA package then use flux along with the specified solder sphere.
            If the BGA package requires a high temperature solder sphere ,apply solder paste with the help of a stencil, and place the high temperature solder sphere. This process is much recommended.The re-balling temperature will allow the solder to reflow and attach the high temperature sphere to the component pad.
            I also found many such companies at Toronto which helps us with the bga reballing and repair issues and was very much satisfied with their services.Hope you got a clear picture.
            • Chris Edwards
              • Aug 2017
              Re: BGA reballing
              BGA reballing means placement of new solder balls on a used BGA. Residual Solder RemovalThis section deals with the process related issue of eliminating residual solder once a component has been removed from a PCB.
              • Stanley1843
                BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                by Stanley1843
                has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                06-22-2024, 11:06 AM
              • petemanuk
                Z270 PCH Reballing help needed pls
                by petemanuk
                I'm trying to reball a Z270 PCH, i've got the right stencil for the PCH and it's direct heat type.
                I initially tried using 0.3mm solder balls (leaded type) but am having lots of problems with the balls not wetting to the chip, basically some of them just wont solder to the pads.
                I'm making sure the chip is as clean (using ipa) then putting a thin layer flux on then putting in in the holding jig with the stencil on. I'm the heating to about 400degC with minimal airflow (4% on my Atten) but some balls just refuse to stick!!
                I've repeated the above using...
                01-28-2023, 12:19 PM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • myth77
                direct heat stencil,where do you get it? and how to prevent warping?
                by myth77
                So, lately i found that for smaller chips like pch it is very difficult to reball with nondirect heat stencil. So i decided to try direct heat stencils...and while i am waithing some stencils to arrive i have a few questions:
                1. From who do you buy a quality direct heat stencils? i am reading that they can vary in quality and make a big difference...Any trusted sellers?
                2. I am reading also the problem of warping (curving) direct heat stencils...Is it because of quality of the stencils? or/and because some preheating is also required? and help and advice here?
                01-17-2022, 05:06 AM
              • dreico33
                Bga Stencil set and base? ,for Vram reballing.
                by dreico33
                Hellow guys,
                I am looking for a good set of stencils and bases(dont kbow exacly the word) for vram exclusive bga reballing.
                Your recomendations are very welcome
                Thank you.
                09-23-2024, 09:00 PM
