LG 47LN5700 Back light issue
  • CANAM13
    • Jul 2014
    • 11
    • usa
    Hello all,
    I recently repaired this tv for a friend and replaced all the led strips from this unit, which I bought at shop Jimmy. TV fired up, looked great and ran fine for about 45 days.I ran the software update, turned down the backlight settings like recommended. But, the unit is dark with another backlight issue.
    I've measured the voltages at the led output plug, i'm getting 78v. when I first turn on the set, voltage is at 130 and then continually decreases till it settles out and stays at 78v.
    P/S board output voltages states - 100v row 47
    110v row 56
    Do I have another LED light/strip issue or should I be checking other voltages from the power supply?
    any help would be greatly appreciated!
    thanks
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 47LN5700 Back light issue
    Looks like a LED Driver issue.
      That sounds like you have open circuit in the LED string, the rated Voltage on the board is with loads connected so if there is no load then output will rise.
      • gliebisch
        • Oct 2017
        • 6
        I have the same problem with similar symptoms. 47LN5700. Board is EAX64905501 (2.3). Strips are LC470DUE SFR1. I should ask , though, whether there is any significance to the LED- test point (PS output connector) voltage. My LED+ voltages with or without strips connected rise to 100 volts initially and then bleed back to 78 volts. However, the LED- test points are both zero volts without a load, but with strips connected, ONE of the two LED- test points reads 19 volts and the other reads zero. With strips disconnected, both of the LED- pins read 0 volts. I am trying to determine whether to try replacing the power supply first, or conclude I need LED strips. One theory I have is that the 19 volts is a phantom voltage from the end of the string caused by the LED- terminal not seeing ground (i.e. a fault on the PS board). Right now these strips are unavailable and out of stock from any source I can find, but I can get a PS board.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          You have an open LED string or strings....
            "the LED- test points are both zero volts without a load, but with strips connected, ONE of the two LED- test points reads 19 volts and the other reads zero."
            The one that show 0 V on the LED - has open circuit.
            L+ is the ANODE the LED string, boosted Voltage is fed to this pin.
            L- is the Cathode return of the LED string.
              LG LN5000 series.
              https://www.badcaps.net/forum/showth...ht=LG+47LN5790
              19V is not the phantom Voltage, that 19V is the Vdrops of the PWM controlled MOSFET and the current sense resistor to maintain constant current through the LEDs,
              The one that reads 0V is due to open circuit so there will be no Voltage on the return line (LED -).
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • PNI E.
                tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                by PNI E.
                hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                02-20-2025, 08:36 AM
              • gurj1979
                Motherboard issue - all voltages OK but no display
                by gurj1979
                I've got a couple of Intel and AMD boards which turns on fine, all voltages at all coils are present, but there is no display.
                I guess this like Code 00 issue.
                I've tried a couple of good CPU's and working Graphics Card.
                PCH has been replaced too. On one Intel board I have even replaced the CPU Socket.
                The CPU's don't get hot, but gets a bit warm.
                All RAMs are good.
                BIOS is good on all.
                PSU is Antec 1000W and I use this for on more powerful boards and 2080Ti cards, so this isn't the issue.
                What's the issue when motherboards have this issue ?
                02-24-2023, 05:53 PM
              • GRANDGG
                LG 42lw4500 flashing red light , wight light , 2 clicks
                by GRANDGG
                Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                05-09-2025, 12:27 PM
              • Manucsl
                QE65Q800TATXXC Samsung TV Issue
                by Manucsl
                Hello.
                My TV is a QE65Q800TATXXC Samsung TV.
                Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                Any ideas to check would be very appreciated 😊
                After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                02-19-2025, 07:47 AM
