samsung ps-r4212 wont turn on
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    power supply: BN96-02213B (PSPF381A01A)
    I have 5v standby
    and I have 160V at the second fuse, which means PFC is working right?
    stby 5v - 4.93V
    ps-on is 4.49V
    d12V - .734V
    d5.3V- .669V
    18V- .633V
    A12V - .735V
    6.5V- 662V
    I'm not sure if all those voltages are supposed to be present during standby
    ps-on does nothing when I press the power button
    power button connector:
    5v - 4.9V
    power- 2.358V -0V/short to ground when button is pressed, normal?
    IR- 3.546V -fluctuates when I press remote
    Suggestions please
    ive searched for schematics but cant find any.
    I have cap and esr meter. some caps are under value but all pretty much with in %10 range
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: samsung ps-r4212 wont turn on
    If ps-on has voltage in standby it will have to be pulled low to turn on power supply. 160v is good for standby voltage. Should go up to 380v or so when powered on.
    • maxvalutech
      • 804
      • australia
      Iif absolutely nothing happens when turn on activated then main board suspect. See other recent posts re isolating main and power boards and jumper powerboard on.
      • sdinelli
        Sdinelli
        • Aug 2014
        • 152
        Right, ive seen where I can force the ps_on low with a resistor from there to ground
        but shouldnt I get some kind of reaction when I press the power button? the PS_ON voltage doesn't come down when I press the button does this indicate that theres something wrong the logic board or the power button?
        • sdinelli
          Sdinelli
          • Aug 2014
          • 152
          so all those other connections with <1V, should they be present in stand by? or only when ps is on? obviously I know VA and VS wont be on.
          • dskall
            • Oct 2016
            • 2905
            • usa
            You should always have a voltage in standby. You may or may not have other voltages depending on design until the mainboard switches them on. If you probe your button connector at mainboard you should have some voltages usually 3.3v one or two should change voltage when buttons pressed
            • maxvalutech
              • 804
              • australia
              Normally you can turn set on from standby with either remote or set switch and if neither gives any reaction at pson then main board is suspect. You need to do the actual test to find out if main is ok or not.
              • sdinelli
                Sdinelli
                • Aug 2014
                • 152
                in the OP I posted the voltages of the power button connector. theres no other buttons but the power and IR.
                the power button connects to the main board.
                I measured the voltage when I pressed the button and it went from 2.358V to 0V. I tested the button with no power at all and when its pressed it shorts to ground. is that normal?
                • sdinelli
                  Sdinelli
                  • Aug 2014
                  • 152
                  Welp I forced the power supply on (first time doing that, pretty exciting)
                  Relay clicked and I got my voltages! VA was on point. VS had no power because I didn't want to mess with forcing that too.
                  any suggestion for what to look for on the main board?
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Difficult without schematics. May have a fuse or two. Might be able to find some chip numbers and specs for them. Look for possible repair kit for it. No other ideas.
                    • maxvalutech
                      • 804
                      • australia
                      Even the professionals only work down to board levels these days. Without or even with a schematic it is hard to trace what is where. On the main board from the pson connector point look for obvious problems and test components as best possible back to standby voltage. Or if you can get a main board at a reasonable price ??
                      • sdinelli
                        Sdinelli
                        • Aug 2014
                        • 152
                        Thanks, il see what I can do.
                        this tv is over 10 years old not worth putting money into it. shop jimmy had the PS board for 24$ but didn't have the main board. it was listed at like 80$
                        • PNI E.
                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                          by PNI E.
                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                          03-17-2025, 04:23 AM
                          09-07-2024, 05:50 AM
                        • tvguy12012012120
                          by tvguy12012012120
                          02-07-2025, 05:13 PM
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • Jackching
                          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                          by Jackching
                          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                          04-15-2024, 05:14 PM
