sony kdl70w840b incompatible new tcon?
  • mj-1
    • Mar 2017
    • 3
    • canada
    I have a sony kdl-70w840b only 1.5 years old.
    Few weeks ago it suddenly started acting up. When you turn it on it would stay on for few seconds and then turn off and give 4 blinking red lights. I bought a used t-con from a tv shop and installed it but when I did it gave me a black screen with flashing orange and green lights.
    So I downloaded the latest firmware from Sony and put it onto a USB drive and plugged it into the TV. It updated but when I turn it on there is no picture (black screen) with a steady green light for few seconds and then goes to flashing red light 5 times.
    So then I plugged in the old tcon and it also flashed orange and green and so I plugged in the USB again and downloaded the firmware. Now when I turn it on it gives a screen with vertical lines and I noticed the tcon makes a weird noise and the processor chip on the tcon gets very hot.
    But I realised that the new tcon I bought came with ribbon cables that are shorter than the original ones so Im guessing that the tcon came from a smaller size tv. My friend told me that a replacement part should come from the same model tv (including size) or else it wont work. Is this true? Is that why im getting 5 blinking red light? Or am I looking at a bad screen? Any information and advice is greatly appreciated.
  • heavymachines
    • Mar 2011
    • 1028
    Re: sony kdl70w840b incompatible new tcon?
    Needs to match panel.
    • mj-1
      • Mar 2017
      • 3
      • canada
      thanks for reply
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • iglitare
        by iglitare
        09-04-2025, 07:13 AM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • rimwall
        Sony KD-65x7500D - double image - Tcon or Panel?
        by rimwall
        This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
        I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
        11-18-2025, 02:09 AM
      • thelankanguy
        Sony KD-55X9000F TCON Issue
        by thelankanguy
        The TV shows a black screen with no image.
        TCON ribbon connectors were disconnected individually for image and there was no half image even.
        Later both ribbons were disconnected and TCON voltages were tested.
        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
        There is also a short to ground in this circled inductor.
        Is this a TCON issue or something else ?...
        12-13-2024, 12:27 AM
