sony kdl70w840b incompatible new tcon?
  • mj-1
    • Mar 2017
    • canada
    I have a sony kdl-70w840b only 1.5 years old.
    Few weeks ago it suddenly started acting up. When you turn it on it would stay on for few seconds and then turn off and give 4 blinking red lights. I bought a used t-con from a tv shop and installed it but when I did it gave me a black screen with flashing orange and green lights.
    So I downloaded the latest firmware from Sony and put it onto a USB drive and plugged it into the TV. It updated but when I turn it on there is no picture (black screen) with a steady green light for few seconds and then goes to flashing red light 5 times.
    So then I plugged in the old tcon and it also flashed orange and green and so I plugged in the USB again and downloaded the firmware. Now when I turn it on it gives a screen with vertical lines and I noticed the tcon makes a weird noise and the processor chip on the tcon gets very hot.
    But I realised that the new tcon I bought came with ribbon cables that are shorter than the original ones so Im guessing that the tcon came from a smaller size tv. My friend told me that a replacement part should come from the same model tv (including size) or else it wont work. Is this true? Is that why im getting 5 blinking red light? Or am I looking at a bad screen? Any information and advice is greatly appreciated.
  • heavymachines
    • Mar 2011
    • 1028
    Re: sony kdl70w840b incompatible new tcon?
    Needs to match panel.
    • mj-1
      • Mar 2017
      • canada
      thanks for reply
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • thelankanguy
        Sony KD-55X9000F TCON Issue
        by thelankanguy
        The TV shows a black screen with no image.
        TCON ribbon connectors were disconnected individually for image and there was no half image even.
        Later both ribbons were disconnected and TCON voltages were tested.
        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
        There is also a short to ground in this circled inductor.
        Is this a TCON issue or something else ?...
        12-13-2024, 12:27 AM
      • bbrain
        Sony KD-55AG9 TCON?
        by bbrain
        I have this problem with my Sony 55' AG9.
        It flashes 4x.
        I have found the service manual, and seems it is the TCON.
        Before I buy a TCON can someone check the vid?
        Thanks in advance!...
        09-19-2024, 10:50 AM
      • rimwall
        Sony KD-65x8500b - bad Tcon or panel?
        by rimwall
        Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
        a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
        b) the Tcon board is malfunctioning,...
        10-24-2023, 07:58 PM
      • swrb898
        Sony KD-70X690E Bravia; Bad TCON? Bad panel?
        by swrb898
        What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
        Problem:
        Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
        My troubleshooting got me this far:
        With the left-hand TCON to bottom-board ribbon cable...
        12-28-2021, 08:12 PM
