OK, today we have got this tv in, and has no picture, the tv turns on with no problems, the LED back lights come on and stay on, but no image on screen from pressing any buttons on tv or remote, no idea at the moment if it has sound, but will try this later, i have re-seated all ribbon cables, including the 2 on the screen tcon, CMO panel, could it be as simple as replaceing the main board, or is there any other ideas out there before i buy one.
Panasonic tx50a300b VESTAL
Tags: None
Re: Panasonic tx50a300b VESTAL
Have you checked the fuse on the Tcon and that it has voltage reaching it.
There is a cheap tcon for sale if there is a problem.
http://www.ebay.ie/itm/TCON-LVDS-PAN...MAAOSw2xRYRCfhWilling to help but I'm no expert. -
did'nt even think about it Dick,
now if it was a stand alone T-CON, it would have been my first port of call, strange how i never even thought about it, but thats why i posted on here,
i'll check it later when i get back, the T-CON is on the screen tabs, not stand alone.
thanks m8.Last edited by finntricky; 03-10-2017, 05:44 AM.Comment
Good news is the fuse is fine, but after exposing the full board, i found a screen tab that was getting very hot,
after very close inspection, it turns out it has shorted out, sparks and smokes, so that renders the screen F****D,
looking on the bright side, i now have loads of spare LED's, and a set of boards LOLComment
by Daren87Hello everyone,
I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM -
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
