Have Vizio M420sv that had no audio and 4 bad caps. Little freeze on tpa3110Ld2 and audio returned . Replaced 4 caps but didn't have a tpa3110Ld2 to replace audio ic. I tried in vain to find datasheet for tpa3110Ld2. Could only find tpa3110d2. I replaced the tpa3110Ld2 with a new tpa3110d2 and the audio works fine. MY question is what is the difference between the ld2 and the d2 chip. Also would you just leave the tpa3110d2 in the TV or replace it back to a tpa3110Ld2 when it gets here from china. The tv has 4 ohm speakers. The only info i found is that the tpa3110Ld2 was a 10 watt and the tpa3110d2 is a 15 watt audio out.
Thanks for any info
Thanks for any info
