Re: Panasonic TX-P42GT20B - Stuck Stby
Well, I'm on the verge of giving in.
A new A board and a new P board, together, do not work. 10 binks. I have made sure every wire in connectors P6 and P7 work/have continuity. No other connectors are connected at all. No D board, no SC, no SS.
What does this mean? Have I been sent a defective A or P board? I don't see a way for me to find out unless I order yet another.
Well, disaster struck. The replaced A board had the exact same issue. 10 blinks. I'm thinking it surely has to be the power board.Leave a comment:
Yes, replace the A board. It's extremely unlikely to be P or SS.Leave a comment:
I've given it my best shot, according to the 2010 Viera training seminar PDF posted earlier in this thread, if the voltage between A6 pin 1 and 9 is 15v just before the TV shuts down, the problem is the A board.
My only worry is that although very similar, this PDF is for VT20T series TVs. Will this rule still apply? Shall I go for the A board replacement?
ThanksLeave a comment:
How can I rule out the P and SS board?Leave a comment:
Most likely the A board is bad then.Leave a comment:
Hey,
Sorry to dig up this post but I've been following along with the same model, and I've had different results - and so hit a brick wall.
I tested voltages across P11 pins 1/4 and P2 pin 1 with the SC connected/disconnected, and got these results:
SC Disconnected
P11 pin 4 = 15.6v
P11 pin 1 = 208v
P2 pin 1 = 209v
SC Connected
P11 pin 4 = 16v
P11 pin 1 = 208v
P2 pin 1 = 208v
Also, no continuity between the Q661 legs.
I believe this rules out the SC board?
I get 10 blinks with the SC both connected and disconnected
I get 10 blinks with the D board (D25 connector) connected and disconnected
I have visually checked every port on the A board for damage or bent pins and I have not found anything.
I'm stuck, I'm a beginner at this so I can't work out what to test next, any guidance is extremely appreciated.
The only extra info I've found is that there is no voltage across P2 or P11 when D25 is disconnected, but from what I've found this is normal.
Also by some crazy coincidence live in the same town as benjamin - feel free to come and fix it if you're a pro these days.Leave a comment:
Maybe buffer board connections
https://www.youtube.com/watch?v=h4XWCxUsSVULeave a comment:
Replacement SC board did the trick, now i have 3 horzontal lines on screen tried mirror in service mode but as they are in centre of screen they stay the sameLeave a comment:
i hooked it up (SC50 Bypass) no error flash, solid green light on tv.
led bright on SC and SS.
performed short test on sm board ribbon connectors - no short.
so if i now install the AW fully it'll fire up as it should do with AH installed?
i have got a copy of both of the manuals.Leave a comment:
Then get a copy of the manual for your model, a copy of the TX-P50G20B or E as that is the model which uses rev AW
Then visually look for differences or compare all C16xxx and L16xxx parts numbers and locations to determine what is the same, what is different.
If you have the boards laid out in front of you you'll start noticing the differences.
I'm not going to work it out for you. I've never done it but it's feasible or return the board and get the correct oneLeave a comment:
and if its just coils and caps which i am capable of but anything involving micro surgery then i'd be at a loss!Leave a comment:
well, if you have a meter in diode and continuity beep, place one probe on SD/Su board gnd plates(bolt plates) and slide the other carefully along the contact pins on the output ribbon connectors watching for dead short.Leave a comment:
ok passed bypass test, how do i make sure sm didnt blow sc board to start with?Leave a comment:
make sure the SD/SU gnd bolts are not bolted to the SC as well if doing that bypass test.Leave a comment:
Well my replacement SC board arrived this morning..............
.......However, the board that i received is a "fully tested" TNPA5081 AW.
I assume that as one is for the 50" and the other for the 42" board needs returning?
good news is that Q661 is ok (wry smile)
TXNSC11NEK or TNPA5081AH
Since the same board is used in both the 2D and 3D models you may get away with it for a quick test and confirm that's all you need.
But, i would check the sd and su boards are not shorted or perform the 7 Blink SU/SD board isolation test where you fully install the sc bit don't connect the SD or SU, jumper the small 2 pin connector on the SC at SC50 (lower left )
If the TV now turns on and stays on with the green LED, then that would be good and turn the TV off,
Get the right board or you could try converting which would involve swapping out a bunch of capacitors and coils from your old board to the replacement.Leave a comment:
good news is that Q661 is ok (wry smile)Leave a comment:
Before you put the new board in check it over carefully, do those resistance readings on it especially on Q661. I recently bought a "working" tnpa5081. Found Q661 shorted right away. Then noticed another IGBT was totally exploded. The exploded IGBT was clearly visible on the guys ebay pic too once I knew what to look for so was not difficult to get a refund.
Yes check buffers for shorts. Make sure all is screwed in tightly and properly connected. You can test the SC with SC50 jumper in before making connection between SC and buffers.Leave a comment:
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
...1 Photo11-20-2024, 08:52 PM -
by Ancient1Hi
The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
Actions :
1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
Obviously the fault is from or on the Right, secondary board
2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...09-03-2023, 03:51 AM -
Hey....
Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand... -
by gigigiPanasonic tx-55cx802b stuck on panel test mode.
It was working normally but few days ago some of the LED reflectors fall off.
I've opened it up carefully, re-glued, while it was open switched it on to test LEDs.
Then carefully assembled back.
After plugging in to power remote does not work.
Using power button on the TV it turns on but gets itself into a panel testing mode: white, gradient, red, gradient, blue, gradient, green and so on switching between colours.
Anyone knows how to get out of this panel testing mode?
I've tried so... -
Hello, I have this TOSHIBA 32AV933G and it is stuck on standby LED (red). It doesn't turn on and the 12V is missing. Anyone has any experience with these PSUs and what to check? (DPS-140SP A)
- Loading...
