VIVO PTV43HD no PS-ON signal
  • dkneyle
    • Dec 2013
    • 445
    Re: VIVO PTV43HD no PS-ON signal
    Took to the mainboard with acetone. It shifted any remaining glue, but didn't bring it back to life. Under a high mag lens it appears there may be some VERY small SMT components around the red socket which sends the POWER ON signal missing. Hard to tell if the pads are blank or if some components have 'dissolved' under the glue. I also confirmed the power switch was pulling the voltage down at the mainboard socket just as it should (~3V down to 0V when clicked) so that wasn't the issue. Looks like I'm purchasing that mainboard for A$80 plus post just to say I saved another from the dumpster.
    • dkneyle
      • Dec 2013
      • 445
      Problem identified, solved, but I am so pi**ed off too.
      Turns out the problem was a poor connection at the PS-ON socket and plug on the mainboard (red socket in images I provided). It was covered in that horrible glue and appears to have dissolved the plastic connector and damaged the connection. I'm kicking myself that I didn't explore that further last week. Let me explain the turn of events.
      Ordered a 2nd-hand mainboard at an extraordinary cost of over A$100, but was only one available anywhere. Dropped it in and I still couldn't get the TV out of standby. Wiggled that connector and suddenly we had power on. As I explored further the PS-ON wire just came away from the connector. Got that sorted, power on, but no menus coming up on screen. Could it still be a defective replacement mainboard? Was my original mainbaord defective at all?
      Swapped over and yes, TV came fully to life. Now I'll have the battle of getting my money back for the mainboard. Arghhhh....
      So just watch out everyone for this brown glue gunk. Corrosive to everything it comes in contact with!
      • dskall
        • Oct 2016
        • 2905
        • usa
        Thanks for follow up. Glad everything working and one less in the dump.
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • JayPoorJay
          Converting +/- 5v to a Usable Hz Signal
          by JayPoorJay
          Good morning.
          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
          08-07-2022, 08:35 AM
        • Mirenia
          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
          by Mirenia
          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
          03-30-2025, 06:47 AM
