Samsung UN55HU7200 not powering on, no blink code
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung UN55HU7200 not powering on, no blink code
    Originally posted by withalligators
    This guy seems to think they are the same as well:
    https://www.amazon.com/difference-be...sin=B00KJEZIEU
    The other commenter says the un55hu7200 does not have the 3D function
    • withalligators
      • Jun 2013
      • 267
      I saw that too. Neither of them have 3d. Which is why you can never trust anecdotal Internet info.
      • withalligators
        • Jun 2013
        • 267
        So, shopjimmy got back to me with a pretty cut and paste "sorry, we don't offer technical support at this time" answer. Oh well, any advice one way or the other before I pull the trigger?
        • withalligators
          • Jun 2013
          • 267
          Welp, I gambled on the cheaper board, the BN94-07777A, from the 55hu7250 version. No dice. Same exact symptoms. So either they're not compatible, or something is wrong in the panel. Luckily I bought it in an auction for 34 with shipping. Sooo, should I just buy the right board and sell the other one, right?
          Cheers
          • withalligators
            • Jun 2013
            • 267
            Guys, there's no way it's an LED, right? I don't have to worry about taking apart the panel? The backlights couldn't come on, period, correct?
            • brucetv
              • May 2015
              • 281
              • united states
              #26
              I've gotten bad boards from SJ before and their return process is fast and easy. But since you bought the kit you will need to ship the whole kit back. It's possible you have a bad panel as well. I suspect you just got a bad main board with that kit. Your led's are fine if they are coming on when you have the cable disconnected from the main. These days sometimes it can be something stupid like a bad Bluetooth module or Wi-Fi module causing the Tv not to turn on.
              • dskall
                • Oct 2016
                • 2905
                • usa
                #27
                Yes I would like to know how a Wi-Fi module will keep a tv from turning on. I know it happens. Iv's seen the posts. I wish someone could give technical explanation as to why.
                • withalligators
                  • Jun 2013
                  • 267
                  Right, I've already shipped the kit back. After that, I bought a different main board off ebay from a unit that was working but had a cracked screen (purportedly). It was for a different (but allegedly the same) model, the 55hu7250 (mine is the 7200). I gambled on it because it was much cheaper. Inspecting it, it's a little different. It's missing the little reset button (or whatever it does, I can't figure it out) and missing a little soldered on bumper. I thought that was enough to indicate that the board was indeed different, but now, after some close examinations of ebay boards, both variants appear to be both with and without the button and bumper. Now, I'm wondering if the board is incompatible, or if there is something insidious and hard to diagnose wrong with this TV. Like something simple like a bad cable somewhere.
                  If the backlights come on by disconnecting the main and power, that indicates they are fine, right? Could there be something wrong with the actual LCD panel? I don't see how that would prevent a turn on. I've had cracked tvs still turn on and work fine otherwise.
                  • withalligators
                    • Jun 2013
                    • 267
                    Interestingly, while plugging in the old board, I noticed that if you press the little reset button on the main and the big relay on the power board clicks, the indicator LED also turns off as if the TV is powering on. Then a second later the light comes on and there is another relay click. If you hold the button the shut off action is delayed til you release it.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      #30
                      A panel can prevent turn-on if it is shorted which is usually tab driver or panel board. Cracked screens usually don't short they have opens.
                      • withalligators
                        • Jun 2013
                        • 267
                        OK. With no blink code? Would there be any symptoms? Is there any way to test that? I ask because I've had many TVs with bad tab bonds that were either fixable with thermal pads or a totally lost cause. But they turned on and functioned, just with a bad picture.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          #32
                          Bad tab bonds are generally opens. By putting pressure on them you are reconnecting them. You can have shorts on panel boards etc. that can take out your t-con and shut tv down.
                          • withalligators
                            • Jun 2013
                            • 267
                            Rats. So is that what I probably have? Never encountered it before. It's always been obviously the panel or fixable. Or a bad LED.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              #34
                              I was only commenting on post 28 that a panel can have shorts that will keep tv from coming on.
                              • jason123
                                • Oct 2015
                                • 1060
                                Hi there.. did you ever figure out the issue? I am having the Exact problem with my set.
                                • withalligators
                                  • Jun 2013
                                  • 267
                                  Hey Jason, never solved it. Pretty sure it wasn't the mainboard. I ended up with not enough time to do a full teardown to check the LEDs, but that would have been my next step.
                                  Good luck, and if you do figure it out I'd love to know.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #37
                                    disconnect the wifi card and see if the set will start up then.
                                    • jason123
                                      • Oct 2015
                                      • 1060
                                      I disconnected wifi and bluetooth modules, no bootup. I pretty much repeated what was done, and all i get is a relay click every 15 seconds or so
                                      • neilc6
                                        • Nov 2015
                                        • 1550
                                        What happens if you disconnect one side of the tcon at a time? If backlights turn on with main board disconnected and no video with either side disconnected, I would suspect tcon.
                                        • jason123
                                          • Oct 2015
                                          • 1060
                                          I tried disconnecting the panel 1 ribbon at a time, I disconnect Main to TCON, one ribbon at a time.. no impact at all on the behavior. It's doing the same thing; no backlight, and just relay clicks every 15 or so seconds. Seems it's in a reboot sequence.
                                            09-07-2024, 05:50 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
