Samsung UN55HU7200 not powering on, no blink code
Re: Samsung UN55HU7200 not powering on, no blink code
I saw that too. Neither of them have 3d. Which is why you can never trust anecdotal Internet info.Comment
So, shopjimmy got back to me with a pretty cut and paste "sorry, we don't offer technical support at this time" answer. Oh well, any advice one way or the other before I pull the trigger?Comment
Welp, I gambled on the cheaper board, the BN94-07777A, from the 55hu7250 version. No dice. Same exact symptoms. So either they're not compatible, or something is wrong in the panel. Luckily I bought it in an auction for 34 with shipping. Sooo, should I just buy the right board and sell the other one, right?
CheersComment
Guys, there's no way it's an LED, right? I don't have to worry about taking apart the panel? The backlights couldn't come on, period, correct?Comment
I've gotten bad boards from SJ before and their return process is fast and easy. But since you bought the kit you will need to ship the whole kit back. It's possible you have a bad panel as well. I suspect you just got a bad main board with that kit. Your led's are fine if they are coming on when you have the cable disconnected from the main. These days sometimes it can be something stupid like a bad Bluetooth module or Wi-Fi module causing the Tv not to turn on.Comment
Yes I would like to know how a Wi-Fi module will keep a tv from turning on. I know it happens. Iv's seen the posts. I wish someone could give technical explanation as to why.I assume no responsibility for any stupid suggestions I might post.Comment
Right, I've already shipped the kit back. After that, I bought a different main board off ebay from a unit that was working but had a cracked screen (purportedly). It was for a different (but allegedly the same) model, the 55hu7250 (mine is the 7200). I gambled on it because it was much cheaper. Inspecting it, it's a little different. It's missing the little reset button (or whatever it does, I can't figure it out) and missing a little soldered on bumper. I thought that was enough to indicate that the board was indeed different, but now, after some close examinations of ebay boards, both variants appear to be both with and without the button and bumper. Now, I'm wondering if the board is incompatible, or if there is something insidious and hard to diagnose wrong with this TV. Like something simple like a bad cable somewhere.
If the backlights come on by disconnecting the main and power, that indicates they are fine, right? Could there be something wrong with the actual LCD panel? I don't see how that would prevent a turn on. I've had cracked tvs still turn on and work fine otherwise.Last edited by withalligators; 04-22-2017, 05:22 PM.Comment
Interestingly, while plugging in the old board, I noticed that if you press the little reset button on the main and the big relay on the power board clicks, the indicator LED also turns off as if the TV is powering on. Then a second later the light comes on and there is another relay click. If you hold the button the shut off action is delayed til you release it.Comment
A panel can prevent turn-on if it is shorted which is usually tab driver or panel board. Cracked screens usually don't short they have opens.I assume no responsibility for any stupid suggestions I might post.Comment
OK. With no blink code? Would there be any symptoms? Is there any way to test that? I ask because I've had many TVs with bad tab bonds that were either fixable with thermal pads or a totally lost cause. But they turned on and functioned, just with a bad picture.Last edited by withalligators; 04-22-2017, 07:00 PM.Comment
Bad tab bonds are generally opens. By putting pressure on them you are reconnecting them. You can have shorts on panel boards etc. that can take out your t-con and shut tv down.I assume no responsibility for any stupid suggestions I might post.Comment
Rats. So is that what I probably have? Never encountered it before. It's always been obviously the panel or fixable. Or a bad LED.Comment
Hey Jason, never solved it. Pretty sure it wasn't the mainboard. I ended up with not enough time to do a full teardown to check the LEDs, but that would have been my next step.
Good luck, and if you do figure it out I'd love to know.Comment
I tried disconnecting the panel 1 ribbon at a time, I disconnect Main to TCON, one ribbon at a time.. no impact at all on the behavior. It's doing the same thing; no backlight, and just relay clicks every 15 or so seconds. Seems it's in a reboot sequence.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
