Samsung UN55HU7200 not powering on, no blink code
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #41
    Re: Samsung UN55HU7200 not powering on, no blink code
    have you got any freeze spray i wonder if its worth freezing the nand and see if the set starts up.
    • nomoresonys
      • 12330
      • U.S.
      #42
      Check over the powerboard solder joints real closely.
      • jason123
        • Oct 2015
        • 1149
        Looks like a replacement main board did the trick. Working fine now.
        Wonder if it's an EEPROM thing. Here is what's odd, the board I received booted with Korean Language. Which is odd, since the supported languages are French, English and Spanish Only. Wonder if the seller installed a replacement EPROM from Korea / China?
        I was able to revert back to English.. but I thought it was odd.
          09-07-2024, 05:50 AM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
