Samsung UN55HU7200 not powering on, no blink code
  • withalligators
    • Jun 2013
    • 267
    Hey folks,
    Haven't had a project in a long time. Kinda rusty at diagnosing. Got the aforementioned Samsung off the side of the road. Screen appears uncracked and fine. Plugged it in, hear a relay click, red LED indicator comes on, stays on. Button presses do nothing.
    Unfortunately, all my tools were stolen, all I have right now is a crappy $3 multimeter. Here's what I've done. I pulled the back, and tested the outputs from the power supply to the main. Both A5V show 5V in standby. All six B13V show 13V in standby. PS ON/OFF shows 3ishV. Nothing seems to change when the on button is pressed.
    No obvious puffy caps or burnt components on main or power. Nothing causes the red LED to change
    Soooooo, whaddya think? Seems like a main issue to me, but I'm rusty, like I said. I want it to be a power board issue, cause its cheaper, but I don't think it is. Tell me I'm wrong. If you guys think it'll help, I'll post pics.
    Thanks!
    Alex
    Re: Samsung UN55HU7200 not powering on, no blink code
    First we need good clear pictures of the whole back side of the TV showing all the board.
    What is the power supply board P/N? BN44-00781A??? This board is also known for bad solder joints, especially around the transformer legs that are fed through the through hole rivets.
    What do you have for BL-ON (BLU_ON/OFF)?
    • dskall
      • Oct 2016
      • 2905
      • usa
      So it stays in standby? Does pson need to be pulled low? Have you tried remote? Checked buttons to see if they change voltage?
        PS-ON is working otherwise he will not have the switched B13V so part of the main power supply is working..
        PS-ON and BL-ON are Active HIGH in this TV. See if BL-ON is also stuck HIGH.
        Which are your boards?
        http://www.shopjimmy.com/catalogsear...ung+UN55HU7200
        Disconnect the cable between the main board and the power supply/LED driver board to see if the Backlights will come on and stay on, if it does then you have problem with the main board, which then you can try disconnecting the WIFI module to see if the TV will function.
        • withalligators
          • Jun 2013
          • 267
          Thanks for the prompt replies. I drove over to work on it. Power board is indeed BN44-00781A main is either BN94-07917A, or BN97-08902A.
          Sorry if I wasn't clear before, no readings change when I press the button.
          When testing BLU_ON/OFF, I get no reading. I get a negative reading if I put the second probe on UD.
          Diconnecting the main and power does indeed turn on the back lights. Testing BLU_ON/OFF turns the back lights off and gives me a reading of about 0.1V (not a digital multimeter). Removing the probe turns them back on.
          Diconnecting the WiFi module doesn't do anything. At least, pressing the power button causes no reaction.
          I'm on a metered connection right now, I'll get home and post the (terrible) pics of the guts.
            So you did the power supply/LED driver board self test by disconnecting the cable between the power supply board and the main board and you get the backlights to come on.
            Disconnecting the WIFI did not make any different so it means that there is problem on the main board some where.
            • withalligators
              • Jun 2013
              • 267
              Hey folks, so, I got sent on a project before I was able to fiddle with this again. While away, I ordered a repair kit from shopjimmy, which included all the boards for a measly 80 bucks. Well, I got back today, and excitedly opened the back of the TV, opened the box, and installed the new main board. Same issue. Perplexed and disappointed, I pulled the cable between the main and power, and the backlights turned on. I then proceeded to replace every component in the TV with the ones from the repair kit. No change in behavior with any component.
              So, what do you guys think? The backlights seem fine. Do you think I got a bad main from SJ? They're usually so good.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Measure your button connector at mainboard for voltage change when buttons pressed. Have you tried with a remote?
                • withalligators
                  • Jun 2013
                  • 267
                  I've done that. I get voltage change. I also swapped it out for the new button that came with the kit. At this point I've swapped main, tcon, power, Bluetooth, WiFi, ir receiver, and button. So something has got to be bad, right? It's basically a whole new TV, right? If an LED had gone bad, they wouldn't come on and stay on when testing, correct? I had a bad led in a Sammy before, and it would turn on and turn right back off.
                  Cheers
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    I think we need to start over with do you get image on screen with flashlight?
                    Need good clear straight on pictures of back of tv with cover off and each board.
                    Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
                    Format:
                    Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
                    1 - XXXXXXX - XXv - XXXv
                    2 - XXXXXXX - XXXv - XXXv
                    3 - XXXXXXX - XXXv - XXXv
                    4 - etc.
                    • xristos glezellis
                      • Mar 2017
                      • Greece
                      Check for fuse or vatika resistance ohm
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        Maybe the boards you recived came out of a smashed screen set so they may not of been tested properly it does sound like a faulty mainboard still too me
                        • withalligators
                          • Jun 2013
                          • 267
                          TV with the back off (all the new components):
                          Main:
                          Power:
                          T-con (heat sink/shield off):
                          Closeup of pinout from PSU to main:
                          I'll get around to retesting the pins shortly. Still sounds to me like the main I got is crap. I haven't shined the screen with a light, but it's not turning on. There are no relay sounds, no change in the indicator LED, nothing.
                          Backlights DO come on if you disconnect the ribbon cable between the PSU and main. This is what makes me believe its not a backlight short / issue.
                          • petehall347
                            • Jan 2015
                            • 4449
                            what happens with just power cable to to main and nothing else ? do the voltages look correct going to main ?
                            am wondering if its something silly like a shorted speaker .
                            • withalligators
                              • Jun 2013
                              • 267
                              Interestingly, there's a small button on the main board in the bottom right (SW1200_DB) that when pressed, elicits a click on the power board. Not sure what it's supposed to do though.
                              Nothing happens with the speakers, BT, wifi, IR, and then disconnected though.
                                Do you still get the same result as in my post 6?
                                • withalligators
                                  • Jun 2013
                                  • 267
                                  Yessir, same results all around. Am I being hasty by returning the set to SJ? Or should I hold on to it for a few days for testing purposes. Literally everything I've tested is the same.
                                  • withalligators
                                    • Jun 2013
                                    • 267
                                    Hey guys, quick question: the main in my TV (55hu7200) is the BN94-07917A. The cheapest are around 100 on ebay. There is a similar model, the 55hu7250, with a different part number main board, BN94-07777A (though they're both variants of the BN97-08902A circuit board). This board is 70 on ebay. Do we think they're interchangeable?
                                    My previous experience with Samsung models that only differ in a 50 at the end is that they are for different retail outlets (ie Costco) and I successfully used one main board in the other.
                                    What do you guys think?
                                    Cheers
                                    • withalligators
                                      • Jun 2013
                                      • 267
                                      This guy seems to think they are the same as well:
                                      https://www.amazon.com/difference-be...sin=B00KJEZIEU
                                        I would verify for sure with shopjimmy to see if there is any requirement to do any firmware update if you do use the same original board.
                                        http://www.shopjimmy.com/samsung-bn9...main-board.htm
                                        http://www.shopjimmy.com/samsung-bn9...hu7200fxza.htm
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
