need some help
  • max powers19
    • Feb 2017
    • 9
    need some help
    Hello I'm new here and I have a question I was hoping someone would be able to help me?
    I can't leave the main menu and I've tried using a mouse to navigate with no luck. Ive been able to find out that it is a chi mei innolux lcd serial number (m220z1-lo3) there's also some other numbers on here ( 89c1q0905ng0003 and cm22z13166tn4npa05m0035) display but I do not have the remote for it so I have no clue how to use this! Do I have to hook a computer tower up to this or can I just put USB stick in? is there a universal remote code? Any help would be amazing!!! Thank you if you need any other info please let me know
  • maxvalutech
    • 804
    • australia
    Re: need some help
    Sorry mate you have lost me !! Is this a tv or a monitor or what?
    • max powers19
      • Feb 2017
      • 9
      Re: need some help
      I believe it is a monitor. It's basically just the lcd panels encased in a steel frame. There is a board on the side with a USB connector and a SD card slot.
      • max powers19
        • Feb 2017
        • 9
        Re: need some help
        i have some pictures of it if that helps
        • R_J
          • 9553
          Re: need some help
          That label seems to be just for the display panel, what is this thing connected to? What is connected to it right now that is puting the video of the gears on the screen?
          There must be a main board, a power supply etc. also
          Usually there are a few buttons that are connected to the main control board to control the on screen menu
          Is there a touch screen that normaly goes over the display screen?
          • max powers19
            • Feb 2017
            • 9
            Re: need some help
            the panels on the bottom are touch sensors but touching them just takes me to a blank screen. there are 4 boards on this thing, 3 green and 1 white. there is a in line power supply. I've looked this thing up and down and it seems the only thing I can control is the volume knob on the top of the monitor. here are pictures of the 4 boards.
            • max powers19
              • Feb 2017
              • 9
              Re: need some help
              Hopefully it didn't have a touch screen cover over top because It didn't have it when I got it.
              • maxvalutech
                • 804
                • australia
                Re: need some help
                This merged company 2010 produces TFT LCD panels for a lot of big companies including tv manufacturers. Probably need to Google it and search.
                • R_J
                  • 9553
                  Re: need some help
                  You are missing the keyboard that connects to CN7, You should be able to make one with a few buttons
                  • max powers19
                    • Feb 2017
                    • 9
                    Re: need some help
                    How would I go about making this? I don't have a clue how to make things like that!
                    • R_J
                      • 9553
                      Re: need some help
                      This is too complicated? then connect a wire to CN7 Pin 4 (or Ground) and touch the other end of the wire to one pin at a time (pin 1, 5, 6, 7, 8, 9 or 10) and see which one has the desired effect
                      That plug (CN7) is where the keyboard plugs in, You don't have one so what else are you going to do?
                      I can't tell which is pin 1 but if you check on cn7 pin 4 will be connected to ground, that will tell you which way the plug is numbered
                      I also don't know which button S1 - S7 would be, looks like its Power, Menu, Vol+, Vol-, Input, Exit
                      • max powers19
                        • Feb 2017
                        • 9
                        Re: need some help
                        I'll give this a shot. Ive never really done this kind of thing or even taught myself wiring blueprints thanks for all your help and hopefully I'll be able to make this work!
                        • R_J
                          • 9553
                          Re: need some help
                          Note: these are normaly open momentary switches.
                          The way it works is each button has a certain function, when the switch is pushed it takes that line to ground. So if S1 was the power switch when it is pushed it takes the K0 line to ground telling the microprocessor to turn off or turn on the monitor, if S2 was the Menu, pushing it would take K1 logic line to ground turning the menu on and off. etc.
                          It would be easier to navigate the menu with the keyboard, so you only have to push a button to change items. maybe a local electronic shop would have a plug that fits CN7 and an old keyboard with a similar switch arangement.
                          • R_J
                            • 9553
                            Re: need some help
                            What you want is similar to this but with 7 buttons and 10 pins http://www.ebay.com/itm/Universal-LC...kAAOSwd4tUCDcO
                            Getting closer https://www.aliexpress.com/item/2pcs...208.4.8.LpgIzF
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Re: need some help
                              The aliexpress one looks the closest match to what is needed. Good find.
                              • max powers19
                                • Feb 2017
                                • 9
                                Re: need some help
                                This is great! Thank you so much for your help. I'm gonna order one of these soon and I'll let ya know how it goes! Thanks again!
                                • cstout
                                  DeLonghi AC Remote only accepts 3V
                                  by cstout
                                  Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                  The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                  I can't find any schematics...
                                  06-03-2024, 03:53 PM
                                • Mc_Millian
                                  Toshiba 50lf711u20 fire tv remote not pairing
                                  by Mc_Millian
                                  I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                  The Tv model number is: 50lf711u20 Rev B.
                                  I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                  I've tried 3 different remotes which should be fully compatible with this TV.
                                  Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                  The power button, along with the volume,back,select, and directional...
                                  04-07-2022, 12:15 PM
                                • edugimeno
                                  HiSense 55A7500F won't obbey to remote after power on
                                  by edugimeno
                                  Hi! I have this TV set that does the following:
                                  1) I press the red power button on the remote
                                  2) The TV turns on normally
                                  3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                  4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                  Then after it's off, it would again accept the TURN ON from the remote and same again
                                  BUT:
                                  -The remote does show the correct IR beam while observed thru a phone camera
                                  -The TV works fine while using the MiRemote...
                                  03-14-2023, 11:22 AM
                                • tmhobadcap
                                  Pioneer VSX-522-K remote control not working???
                                  by tmhobadcap
                                  I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                  At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                  12-24-2020, 01:44 AM
                                • rustinjust
                                  Please help, where can I get a remote for my subwoofer?
                                  by rustinjust
                                  I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                  Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                  Is there...
                                  10-28-2023, 03:43 AM
