Re: Emerson LF401EM5 LED TV no power won't turn on
I'm gonna go ahead and do that. Get a cheap board then get the repair kit from shopjimmy and try to repair the old board too just for the heck of it.
I appreciate everybody's advise. I feel pretty confident this TV will be back in operation with a replacement PSU and without buying a whole new TV.
Thanks Yall!!
i have not got a variac myself but do use a 100w bulb in series after psu repairs if a replacement mainboard is really cheap in this case i would get one so the sets working etc then i would still probably repair the old board as you have more time to test and a working board to compare resistance readings on etc depends too on how the op feels like soldering smd parts too i guess.Leave a comment:
i personally agree with post 2 and peplace the power board it only takes one part too be missed (we have seen this before with plasma repair kits that not all parts are included) and all the new kit blew again look on ebay etc as im sure you will be able too get a board a lot cheaper just get one with a returns policy etc if faulty.
For the op: You may want to check everything, including those green resistors for proper resistance. Resistors go higher in value or open when bad.Leave a comment:
i personally agree with post 2 and peplace the power board it only takes one part too be missed (we have seen this before with plasma repair kits that not all parts are included) and all the new kit blew again look on ebay etc as im sure you will be able too get a board a lot cheaper just get one with a returns policy etc if faulty.Leave a comment:
They give locations for were the parts go.Leave a comment:
With that fuse being blown it should have protected the main board and the rest of the TV components. I feel pretty confident the damage is limited to the PSU at this point.Last edited by Toddo; 02-21-2017, 09:09 PM.Leave a comment:
Sorry I meant you need to test each pin on connector going to mainboard. You might want to buy the repair kit from shopjimmy and see if that fixes it.Leave a comment:
The blue circle is a transistor and if reading between all three leads maybe bad so remove it and retest the red circles are diodes best to unsolder one side and lift a leg and retest the blue rectangle looks like a fuse test the same part on your board and see what it reads
reagarding the 88v reading on the mains connector it depends what you was using as a ground as your working on the hot side of the psu use the negative side of one of the large capacitors as a ground on the cold side of the psu you can use a grouding screw etc.
All 3 legs of this transistor still has continuity:
The 1 diode in this pic looses continuity with leg lifted. The other still has continuity:
And this diode still has continuity with a leg lifted:
Some diodes I test for continuity ring out for a brief second then loose it. Don't know what that's about. But the three I have pointed out had continuous continuity.
I got 91V on the hot lead of the power connector and going to a ground screw on the cold side.
Ribbon cable to main board: Blue Circle
To display?: Purple Circles
Bottom:
Whole thing:
Need picture of your connector that plugs into your main board. I don't see pinouts. Need picture of back of board maybe the pinout is on back. Should be at least one pin with voltage. Well pictures from shopjimmy are not showing pinouts on either side.Last edited by dskall; 02-21-2017, 02:48 PM.Leave a comment:
Ok well first you need to plug in power supply and see if you have a standby voltage. Check each pin with neg. on cold ground metal chassis if board is attached to tv.Leave a comment:
reagarding the 88v reading on the mains connector it depends what you was using as a ground as your working on the hot side of the psu use the negative side of one of the large capacitors as a ground on the cold side of the psu you can use a grouding screw etc.Last edited by vinceroger69; 02-21-2017, 02:45 PM.Leave a comment:
I agree with above post. Buy new board. I am not trying to be mean just practical. To try to lead you step by step explaining the black barrels are diodes, a fuse does not have three leads, 88v on input is not correct but how did you get your measurement and the blue cylinders could kill you. You would be much better off just replacing board. Having said that if you still want help diagnosing. First you need to find out if you have standby voltage if so you will need to force power supply on and check your other voltages and report your measurements.
I found a site called ShopJimmy that has the whole power supply board for the Emerson for like $54, and then they also sell a repair kit with some specific parts that are known to go bad for like $15.
Board:
https://www.shopjimmy.com/magnavox-a...upply-unit.htm
PS Repair Kit:
https://www.shopjimmy.com/magnavox-a...repair-kit.htm
Looking at this ShopJimmy repair kit, the included items are listed as,
Fuses - 1
Transistors - 2
Diodes - 4
Resistors - 1
I know the white component with the stripes is a resistor because I used to be an electricians apprentice and I was also taking electrical classes at the college in order to get my journeymans card. The stripes indicate the specific Ohms of reisistance. If the component in the red rectangle is not the fuse then I'm guessing the little brown component in the blue rectangle is the fuse? Cause there's only one fuse listed and it's the only component of it's kind and it has two leads.
I tested the power connector with one lead of my voltage tester on the hot power lead and the negative just touching the metal case the boards is attached to inside the TV. It read 88.7 volts.
The only reason I'm reluctant to just go ahead and buy a whole new board is because I'm not sure it's even the PS board that's bad. I really would like to figure out if it is indeed a bad part on the PS board and then figure out which part and replace them. If you wanna help me with it I would be very grateful. I have a pretty decent Weller brand soldering iron with adjustable temp control. If not, would it be possible to just figure out if the PS board is actually bad before I waste money on a new one?
I just wanted to add one more thing. I know not to touch anything on any boards or any electrical components inside the TV with my hand with it plugged in haha. Just to ease your mind.Leave a comment:
I agree with above post. Buy new board. I am not trying to be mean just practical. To try to lead you step by step explaining the black barrels are diodes, a fuse does not have three leads, 88v on input is not correct but how did you get your measurement and the blue cylinders could kill you. You would be much better off just replacing board. Having said that if you still want help diagnosing. First you need to find out if you have standby voltage if so you will need to force power supply on and check your other voltages and report your measurements.Leave a comment:
Look on e-bay and get another board to replace the one you have....There are cases where these boards were repaired after much brain picking and a lot of parts, In my view it is not worthwhile fixing since if just one bad component is missed and new one replaced all of the new ones would 'blow' again...Leave a comment:
My son was watching his TV when it just went blank. The TV is only 2 years old. I know almost absolutely nothing about TV repair/troubleshooting. I can't see throwing away this TV and buying a new one when it probably only has about $4.00 worth of bad components that need to be replaced.
Since I'm getting nothing at all I "assume" there's something bad on the power supply. I went ahead and removed the PS and checked out the tops of all the electrolytic capacitors on the board and they're all good and flat. No bulging at all on any of them. I found a YouTube video and learned that the little black barrel components on the board are not supposed to have continuity and I got continuity on the three components with the red circles. Not sure what those are. The one in the Blue circle is a fuse I think and it has 3 leads and I got continuity between all three leads so I think the fuse is good. I plugged it in and tested the voltage at the power connector hot lead in the purple circle and it read 88.7 volts (I tested it with it still installed in the set with all the connectors on and the main board connected to it). Not sure if that's right or not.
Anyone got any advise what to do next?Tags: None
by KYBOSHPicked up a Tektronix type 422 oscilloscope locally for a few bucks last year.
It wouldnt power on at all so I stowed it away under my bench for later testing.
Today I remembered it was down there and pulled it out to see what was what.
I checked for continuity and everything checked out.
There was a burned smell and a resistor was replaced with a temporary replacement (see yellow box in picture).
The burned smell is very pungent/acidic and I am not familiar with these vintage electronics to know whether I am smelling the remains of the replaced resistor or...1 Photo -
by grimacelordHello. I am working on a circuit board that is part of a motorized HDTV lift. The circuit board belongs to the controller component that tells the motor to either raise or lower the HDTV height.
The controller started sparking when the 29V power supply was attached and the green light on the power supply would go out as soon as it was plugged into the controller board. This indicated a shorted component and I was able to identify which component it is that is causing the short. When I remove this component, the short is cleared.
The problem is finding a replacement component.... -
by Mustafa85Hi guys,
Any one has Emerson industrial PSU schematic, it has 3 electronics cards in one package please have a look at pics -
by jkucukovI'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show... -
by littlejohnHello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
- Loading...
