Bang&Olufsen 6-26 with strange picture
  • olegeisler
    • Dec 2016
    • 100
    • Denmark
    Trying to fix this TV for a friend. It is a small LCD, made by Bang&Olufsen, I think the best term is that it is a designer-TV. It was VERY expensive, and the owner really want to have it fixed. Only official way to get parts, is through an authorized B&O dealership, and it is simply chassis or LCD panel exchange. The cost is beyond belief.
    The problem can be seen on picture 2, the picture is "triplicated". It is not always, it happens during startup. If the set starts, it runs - no problem. If it has the "triplicated" picture, it can be remedied by 1 or 2 re-starts.
    Now, I have the opportunity to purchase parts from a set, but the seller knows he can charge a good price - well, that is OK. But which board to go for ?
    The T-con in the top ( pic 5 ) , or the "video controller" ( pic 4 ) - or could it be the panel ?
    The T-con has two flat cables going to the panel, I can dig in to them if necessary, but it will take a lot of disassembly
    Any ideas out there ?
  • CapLeaker
    Leaking Member
    • 8158
    Re: Bang&Olufsen 6-26 with strange picture
    Clean all the ribbon cables / connectors going from the main to Tcon and from Tcon to panel.
    • olegeisler
      • Dec 2016
      • 100
      • Denmark
      Thanks for the suggestion. Removed all connectors / both ribbon cables - cleaned the ribbon cables with cotton swab wetted with "Kontakt 60" contact cleaner. The others just sprayed with "KONTAKT 60" - then re-seated several times.
      At the fifth startup, triplicated picture again
      But, now I tried. Any other suggestions ?
      The panel is now accessible, so I can do all kind of testing.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        What panel does it use ? Looks like tab bond issue to me.
        • olegeisler
          • Dec 2016
          • 100
          • Denmark
          OK, thanks - Can that create such a picture ?
          See attachment for type. Says SHARP LQ255T3LY44
          Can probably buy a panel with T-con, but the cost is UGHH!! so I want to have a good feeling before spending the money
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Have you lifted (removed) one of the Tcon to Panel ribbons to see if you have a good half picture. Then reconnect and try the other ribbon?
            • olegeisler
              • Dec 2016
              • 100
              • Denmark
              No, I didnt - but now I have :
              1. Left disconnected, Right connected : Intermittent "triplicate" half picture / OK picture - just as with both connected, just only picture in one side.
              2: Right disconnected, Left connected : Black screen, no picture at all ( first thought I did not re-connect properly, but reconnecting right gave the below result):
              3: Both reconnected : Back to square one, intermittent triplicate at startup
              Does that give any clues ?
              • dskall
                • Oct 2016
                • 2905
                • usa
                I would concentrate on t-con. Wiggle lvds cable to see if it has effect. Measure various voltages on t-con when picture good compare voltages to bad picture. Since you can replicate failure you should be able to compare readings from different boards when good and bad.
                • olegeisler
                  • Dec 2016
                  • 100
                  • Denmark
                  Only voltage to the Tcon is a 5V, it measures 4.89V to 4.92 Volts.
                  Took a measurement on the first LVDS RIN0- and it looks like PIC 8 with "good" picture, and like PIC 9 with "bad" picture.
                  I also checked the clock, it is approx 84MHz "good" ( PIC7 ) and 65MHz "bad" ( PIC 10)
                  My conclusion is that the fault is somewhere on the mainboard / video process board, not Tcon / panel.
                  Please correct me if I am wrong.
                  And no schematics exist.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Was that with the LVDS cable removed from the Tcon (or mainboard) to eliminate the possibility that the Tcon is corrupting the signal.?
                    • olegeisler
                      • Dec 2016
                      • 100
                      • Denmark
                      No, measured on Tcon.
                      Removed ( with power on ) , and checked the clock, it is 65MHz both measured directly on the cable and on Tcon.
                      Reconnecting the LVDS "live" does change the pictre, still "triplicate"
                      Thanks for your answer :-)
                      • CapLeaker
                        Leaking Member
                        • 8158
                        Try heating or freezing parts of the main board. I guess we need more pics.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Well troubleshooting t-con is above my paygrade, but seems a 20mhz change in clock is beyond tolerance.
                          • olegeisler
                            • Dec 2016
                            • 100
                            • Denmark
                            Update for anyone interested : Heating / cooling seems to have no effect. Error occurs randomly !
                            BUT : I now purchased a set, which should be in poor physical condition, but functional. Will update when I find the solution !
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • JJAAMM
                              by JJAAMM
                              Problem
                              07-06-2023, 06:01 AM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • maxim2511
                              LG 55EC930V OLED - swich on swich of no screen
                              by maxim2511
                              My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                              Then I get an idea to take it apart and clean boards from dust.
                              In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                              Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                              05-14-2021, 02:21 AM
