LST04 LCD Screen Tester
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Has anyone seen this.
    http://lcdparts.net/LST04.aspx
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LST04 LCD Screen Tester
    yes there was a thread a while ago about them ebay sell them and ali express theres a good you tube video showing it in action
    https://www.youtube.com/watch?v=fmviddp0guI
    they do look a good bit of affordable equiptemt
    • dskall
      • Oct 2016
      • 2905
      • usa
      Was going to get one but to me it is just going to tell if it is mainboard or t-con/panel problem. Wish they had a tester that could just test the panel itself. But for the price it can eliminate the mainboard as the problem.
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        well i tried,no more i can do,cheers for the guys on here,
        • vinceroger69
          • Mar 2012
          • 6714
          this one can test just panels
          https://www.youtube.com/watch?v=yFF-ZVEDX54
          • dskall
            • Oct 2016
            • 2905
            • usa
            Small monitors but I don't think you can bypass the t-con on tv's and test just the panel.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              I believe that you are correct in that it can test laptop LCD panels but TV panels through the Tcon board.
              I'll be keeping an eye on it to see how it develops.
              • vinceroger69
                • Mar 2012
                • 6714
                yes sorry didnt realise that untill i have just watched the whole video
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • spice_disc
                  Vizio TV M50-C1 reboot cycle and static on screen
                  by spice_disc
                  I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                  The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                  09-08-2024, 02:37 PM
                • ipatch
                  ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                  by ipatch
                  i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                  08-24-2024, 02:36 PM
