Panasonic tx-55650b
  • modstation
    • Feb 2017
    Panasonic tx-55650b
    Hi
    I have a panasonic tx-55as650b lcd tv which all of a sudden lost its picture, but the backlight was still on. All p/s voltages are good and there is voltage on the output of the t con board. I bought a replacement motherboard and with this one in place there is no backlight the SRV-VLED remains at 24 volts (original m/b switches it to 46v) there is no voltage at srv 12v for t con and the green power led blinks rapidly before going solid. when i remove the ribbon to the panel on one side the other side has vertical lines of various colours which disappear when the ribbon is plugged in. Anyone have any pointers? thanks in advance for any help
    with original m/b in place t con voltages are as follows: v_in 12v
    vdd 0v
    vgh -0.2v
    hvdd 0v
    vcc 3.3v
    vgl -5.1v
    vcore 1.2v
    vep 1.8v
    gclk 1.6v
    mclk 0.1v
    gst 0v
    eo 0v
    gip_bypasson 0v
    vcom top 0v
    vcom bottom 0.1v
    vst -5.1v
    vgh_even -5.1v
    vgh_odd -5.1v
    clk1 through clk6 -5.1v
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic tx-55650b
    So with the original mainboard the tv turns on , has backlight but no picture?
    Does the tv turn on with the replacement board or is it "dead" ? If the backlight stays on then i think you have a problem with the t-con.
    • modstation
      • Feb 2017
      i bought a new m/b and a new t con. with the new m/b no backlight and no 12v on the test point between lvds to tcon so i am guessing its no good. with old m/b and new t con no change just backlight. i took off one ribbon to panel and the other side just has vertical lines. when you switch between sources on tv the backlight changes brightness. I have a feeling panel is bad but not sure how to test to find out for sure.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Hmm , strange! You sure the new t-con is good?
        Here you can download the service manual.
        Wait for the "processing" on the bottom of the page to disappear. It will change to " get manual ".
        Go to page 21 and do the self check. Hope this helps you.
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • zesko
          xps 9520 ribbon cable
          by zesko
          I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
          There is 2 models, idk which one is needed on my laptop.
          0xkvng
          00vpr2
          Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
          Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
          thanks...
          10-23-2025, 05:03 PM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
