Samsung LN55C610N1FXZC no image screen flashes
  • Mayn
    • Nov 2016
    • 54
    Just picked up a Samsung LN55C610N1FXZC.
    Sound works, but no image. Backlights work fine.
    When turning the tv on, I get no image. I do get a, I want to say pulsing brightness on the entire screen,.
    If I disconnect the t-con board, the backlights come on and there is no flashing. As soon as I connect either side of the t-con board the problem comes back. Doesn't matter what input I use, I don't actually get any image.
    I'm guessing bad t-con, but anyone have any other ideas?
    Re: Samsung LN55C610N1FXZC no image screen flashes
    I cannot tell if the T-CON board is at the top center of the LCD panel or at the bottom center of the LCD panel.
    Can we see the whole back side of the TV showing all the boards?
    • Mayn
      • Nov 2016
      • 54
      sorry, the t-con is at the bottom center. I had it flipped to take the shield off to get at it.
        Ooo, one of those tab bonding on the bottom edge of panel that always get damaged when people spray the cleaner on the screen and it drips down all the way to the tab bonding board and causes corrosion and shorts out.
        • Mayn
          • Nov 2016
          • 54
          Oh great lol. Any solution ?
          • Mayn
            • Nov 2016
            • 54
            I took it apart further and looked at the tab bonds. I don't really see any sign of any liquid ever being on them. Turned it on and tapped on them with no difference.
            Does this sound like maybe it's as simple as a bad t-con board?
              You can take a chance with T-CON if it is cheap enough.
              • Mayn
                • Nov 2016
                • 54
                That's what I'm thinking. Might be worth it.
                • Mayn
                  • Nov 2016
                  • 54
                  So I got a replacement t-con board. Installed it and powered up.
                  Got image, but it does seem like a couple bad tab bonds cause of vertical bands in a couple spots. So I left it on for a bit to see what happens.
                  Now I don't get any image at all. Think the bad tab bonds is taking out the t-con?
                  • ulthi
                    Samsung QE50Q60TAU - Flashes black/blue screen
                    by ulthi
                    My tv is not able to turn on. I flashes between black and vague blue screen (see video)
                    I have tried different resets and have also replaced the main board - but nothin has changed.
                    Any suggestions?
                    https://youtu.be/acYQ-ImmhWA
                    10-14-2025, 01:48 PM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
