Samsung LE46C750, power supply BN44-00341A - LOW VOLTAGES
  • jczarniak
    • Oct 2015
    • 179
    TV is starting up (I can hear the startup melody).
    Backlight and sound from HDMI source are present for 1-2 seconds and TV reboots.
    I checked the voltages on power supply.
    Everything looks OK except 13 V line.
    I see only 12.5 V dropping to 12.1 when TV is starting.
    I need your help guys to help me find the fault / faulty parts on the power supply.
    I cant find anything obvious.
    Thanks a lot.
    Re: Samsung LE46C750, power supply BN44-00341A - LOW VOLTAGES
    That 13V is not tightly regulated supply.
    What are the DCV reading on those pins of the connector of the power supply board that goes to the main board when TV is OFF and when power switch is activated?
    You MUST report the reading in this format:
    Pin NAME ????, DCV = ????
    • jczarniak
      • Oct 2015
      • 179
      So, CN802, cable between main board and PSU unplugged:
      PIN 1 - 12.64 V
      PIN 2 - 5.28 V
      PIN 3 - 12.64 V
      PIN 4 - 5.28 V
      PIN 5 - 12.64 V
      PIN 6 - 5.28 V
      PIN 7 - 0
      PIN 8 - 0
      PIN 9 - 0
      PIN 10 - 0
      PIN 11 - 5.28 V
      PIN 12 - 0
      PIN 13 - 5.28 V
      PIN 14 - 5.28 V
      PIN 15 - 12.64 V
      PIN 16 - 5.28 V
      PIN 17 - 12.64 V
      PIN 18 - 0.78 V
      CN802, cable between main board and PSU connected, TV on:
      PIN 1 - 12.28 - 12.45
      PIN 2 - 4.82 - 5.24
      PIN 3 - 12.28 - 12.45
      PIN 4 - 4.82 - 5.24
      PIN 5 - 12.28 - 12.45
      PIN 6 - 4.82 - 5.24
      PIN 7 - 0
      PIN 8 - 0
      PIN 9 - 0
      PIN 10 - 0
      PIN 11 - 4.82 - 5.24
      PIN 12 - 0
      PIN 13 - 4.82 - 5.24
      PIN 14 - 4.82 - 5.24
      PIN 15 - 12.28 - 12.45
      PIN 16 - 4.82 - 5.24
      PIN 17 - 12.28 - 12.45
      PIN 18 - 0.64- 0.72 V
      Thanks.
      • vinceroger69
        • Mar 2012
        • 6714
        PIN 1 - 12.64 V
        PIN 2 - 5.28 V
        PIN 3 - 12.64 V
        PIN 4 - 5.28 V
        PIN 5 - 12.64 V
        PIN 6 - 5.28 V
        PIN 7 - 0
        PIN 8 - 0
        PIN 9 - 0
        PIN 10 - 0
        PIN 11 - 5.28 V
        PIN 12 - 0
        PIN 13 - 5.28 V
        PIN 14 - 5.28 V
        PIN 15 - 12.64 V
        PIN 16 - 5.28 V
        PIN 17 - 12.64 V
        PIN 18 - 0.78 V
        PIN 2 - 4.82 - 5.24
        PIN 4 - 4.82 - 5.24
        PIN 6 - 4.82 - 5.24
        PIN 7 - 0
        PIN 8 - 0
        PIN 9 - 0
        PIN 10 - 0
        PIN 12 - 0
        Thanks.
        can you edit this with the pin names ie ps on bl on 5v 12v etc
          Where are the pin names? Those numbers do not mean anything without the pin names to tell use what those pins are for.
          "You MUST report the reading in this format:
          Pin NAME ????, DCV = ????"
          • jczarniak
            • Oct 2015
            • 179
            Sorry, very busy at the moment.
            I'll change the format tomorrow.
            See the pin names on the picture attached.
            Thank you.
            • jczarniak
              • Oct 2015
              • 179
              Thank you.
              Hopefully that is more clear now.
              Thanks.
              • jczarniak
                • Oct 2015
                • 179
                Thanks.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  ps on pin seems very low? with mainboard connected or unplugged maybe worth forcing on just the psu do all the voltages stay stable and not drop out.
                  • jczarniak
                    • Oct 2015
                    • 179
                    I tried that.
                    I made the bridge between PS_ON and A5V.
                    All voltages going up by about 0.1 - 0.15 Volt but TV still behaves in the same way
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      without the mainboard connect at all? just the psu as we need to rule out the psu first.
                      so does the psu still power cycle on and off with no mainboard connected just ps on connected to 5v through 1k resistors
                      • jczarniak
                        • Oct 2015
                        • 179
                        When main board is disconnected, PSU is NOT in the power on/off cycle.
                        With the bridge, voltages are stable and higher by about 0.1 - 0.15 Volt.
                        Don't remember now how it looks like with cable connected to main board.
                        I'll check that today.
                        I didn't use 1k resistor to bridge the PS_ON and A5V. Is this making any difference, please?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          possible mainboard or backlight led faiure hopefully a more experienced member can advise you more.
                          • jczarniak
                            • Oct 2015
                            • 179
                            Hopefully.
                            Thank you very much anyway.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              It is always safer to use a resistor when jumping pins.
                              • jczarniak
                                • Oct 2015
                                • 179
                                OK, good to know.
                                Thank you.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Backlights should be on when powering up without the main board connected.
                                  PS_ON requires 3V> so if it's falling when connected to the mainboard then it would look like you have a mainboard problem.
                                  Try heat/cool the EEprom on the main board.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Not an Led set buddy, inverter is on the psu
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      i agree lol just looked at the psu picture.
                                      • jczarniak
                                        • Oct 2015
                                        • 179
                                        What I noticed yesterday:
                                        - PSU was unplugged / disconnected for whole night. Checked the voltages with only power cable plugged in and there was 13 Volt on the correct pins, 13.2 with bridge on PSU_ON
                                        - connected the backlight, stil 13 Volt, no backlight
                                        - connected the main board, 12.4 V, no backlight
                                        - disconnected the main board, 12.6 V, backlight ON
                                        - 13 volt didn't came back
                                        - backlight connected, main board disconnected, 12.6 V, backlight ON
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
