Sharp LC-65LE645 Frozen at Sharp Logo
  • mmartell
    • Oct 2013
    • 3189
    I tried finding the firmware to reflash but it seems it was never updated from factory and so is not available for download. Thinking I was looking at replacing the board anyhow I decided to attempt to flash with firmware from a similar set with similar specs and it worked. Firmware was from the LC-65LE654. Don't forget to rename the downloaded flash file to "install.img" Simply copy to the root of fat32 formatted usb stick and place in side usb port then plug in the set.
    Posting on the longshot someone finds themselves in the same bind now or in the future.
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp LC-65LE645 Frozen at Sharp Logo
    good info as lots of people seem to have issues "forcing" a firmware load onto a set via the usb. Most seem to get "stuck" with a "no update found" of equivalent but I think they aren't following a good "process". I think that you should always be able to force a load image assuming the "bootstrap" is functioning.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Is it possible to read the firmware from a set to a USB for archiving or with just some sets?
      • mmartell
        • Oct 2013
        • 3189
        Ya believe me I know about good process - it took me a while to figure out the file name as downloaded from the Sharp website needed to be truncated. After that, as easy as pie lol.
        • raileanu
          TV SHARP LC-26P50E KD186 QKITPD186WJN3 (WE015169S) need working firmware dump set
          by raileanu
          Hi.
          Please if someone help me with a functional firmware dump for this KD186 QKITPD186WJN3 (WE015169S) motherboard from TV SHARP LC-26P50E.
          I think this motherboard it is found in several models.
          What I need is firmware for the NOR chip SST39VF1682 (IC2003) and for the two EEPROMs 24C64 (IC2002) and 24C32 (IC4501).
          I am especially interested in the NOR firmware because I think it has problems.
          The TV initially came only with the red STB LED on and it did not respond to any commands.
          I checked the power supply...
          07-11-2022, 10:07 AM
        • AustinComputerDoctor
          Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
          by AustinComputerDoctor
          I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
          I see backlite is active,
          but I cannot get the screen to return back to menus , etc
          This is all after replacing the mainboard...
          any assistance is greatly appreciated.
          03-25-2024, 12:43 PM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • gurj1979
          Ubiquiti firmware help. US-8-150W POE
          by gurj1979
          Hi guys.
          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
          Got New chip and writes good.
          THE PROBLEM...
          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
          Does anyone have a Good Firmware I can have?...
          07-22-2024, 05:13 PM
