Dell W1700
+ More Options
Posts
  • seanlindo06
    • Nov 2008
    Dell W1700
    I read through a pretty lengthy thread on this site but couldn't come up with a definitive answer, so here they are:
    1. How do I open the unit, it's been unplugged for a couple of months now, is there any remaining electrical hazard?
    2. How can I tell if it's a bad cap, backlight, backlight inverter, or all 3?
  • seanlindo06
    • Nov 2008
    Re: Dell W1700
    3. Why did Dell make such a great TV/Monitor with such shoddy components?
    • Krankshaft
      • Jan 2007
      • 2328
      Re: Dell W1700
      1. No need to be overparanoid most LCD monitors will discharge their caps in seconds after unplugging it. It's CRTs which can hold their charge for months and thats only under the red anode wires suction cup. The charge from CRTs will not kill you (high voltage low current) but it won't be a pleasant experience.
      2. Bad capacitors will have a bulged top or they will push their bung out the bottom. In some cases the caps ESR just goes up and shows no signs of failure. As for how to open it try a Google search I have opened Dell monitors before but not this specific model.
      If it's like other Dell monitors it probably is held together with a combination of clips around the perimeter of the cover and screws.
      I believe that the W1700s inverters like to fail replace the SMT fuses on the inverter and the 2 caps. Beyond that electronics troubleshooting will be required and I'd recommend a new inverter module.
      3. Ask Yum Cha Electronics Dell gave them a price to manufacture an LCD and they met it. Most of Dell's stuff is crap anyway IMO pure lowest bidder manufacturing.
      • roblef
        San Antonio
        • Apr 2010
        Re: Dell W1700
        hey folks,
        yep another newbie to the forum...same dang prob' tho. black screen..sound n power up light. anybody happen to have the specs on the caps and fuses? I gotta try that before i buy a board. Thx
        • mbates14
          • May 2005
          • 169
          Re: Dell W1700
          i ran into a W1700 that actually had a bad flash IC. believe it or not. unit would not do anything until flash IC was very warm, and it powered up.
          So i ended up ripping a copy of the flash IC cold and hot, and there were several byte differences!. keep this in mind. I took the hot flash dump and burned it to a new flash IC, it worked fine afterwords.
          • aliasdck
            • Sep 2009
            • 100
            Re: Dell W1700
            I picked up a dell w1700 at a local ewaste recycler a few months ago. The power led would light but the backlights would not fire.
            Opened it up and found a blown inverter fuse. I probed around and discovered that one of p and n channel mosfets (single package containing both) that drive one of the inverter transformers was shorted. I replaced the fuse, the mosfet ic and also the caps on the board for good measure.
            Now this tv/monitor works but unfortunetly it has a horrible red tint due to aging bulb(s). I have put it aside for a rainy day as I really hate taking apart lcd panels... plus this display uses eight bulbs so it will be expensive as I would replace all the bulbs at the same time.
            • mbates14
              • May 2005
              • 169
              Re: Dell W1700
              thats what caused the inverters to fail in the first place. I would use a large EL strip if you can get them cheap enough, or LEDs with a Fresnel lense to reduce spotting.
              • kelsjon3
                • Jul 2010
                Re: Dell W1700
                I know this is old, but I thought I'd post a link to disassembly instructions:
                • kocoman
                  • Aug 2009
                  • 12
                  Re: Dell W1700
                  Does anyone have a photo of the LVDS cable? the 30 pin side? thanks
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
                  • F R 2568
                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                    by F R 2568
                    Hello all,
                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                    If the laptop is only connected to the AC adapter (battery removed):
                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                    The power/battery...
                    01-08-2025, 05:45 AM
                  • diamon
                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                    by diamon
                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                    Pictures of these boards:
                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                    Dell...
                    02-28-2024, 12:51 PM
                  • lalle-
                    Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                    by lalle-
                    Hello!
                    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                    08-11-2024, 02:01 PM
