Hitachi 42hyt42u Turns off after 3sec - Vestal 17IPS71, 17MB95M
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Hitachi 42hyt42u Turns off after 3sec - Vestal 17IPS71, 17MB95M
    freeze spray a lot of the times does work some times you can then read tha data and re programme another ic etc
    worth watching this video
    https://www.youtube.com/watch?v=Qy8f...ist=WL&index=3
    • Bazilwrc164
      Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
      by Bazilwrc164
      I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
      The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
      I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
      If anyone can provide:
      • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
      • Or a compatible EEPROM dump
      07-23-2025, 12:15 PM
    • dragometin
      Hitachi 40HYC42
      by dragometin
      TV Model: Hitachi 40HYC42
      Power Supply: 17IPS71
      MainBoard: 17MB95M
      Panel: VES400UNDS-2D-NO3
      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
      Is there any variants on 17IPS71 power supply's?
      UART output pins 10 and 12 on scart connector:
      Code:
      12:24:04.595
      08-08-2024, 05:53 AM
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • wolf1976
      hitachi 50hk5600 problem with display
      by wolf1976
      hi
      i have the above tv and the display starts distorts the display at only in applications like you tube
      after and on the didital channels
      now without connect the antenna only the image of itsselfs tv i have the image i have in attach
      i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
      can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
      09-13-2025, 02:26 PM
    • Wompatti-
      Ps5 edm-020 3sec BLOD
      by Wompatti-
      I have a ps5 with blue light flashing about three seconds when I press the power button and then it turns of. Second press, only beeb but nothing else. Third press, 3sec blod etc...
      BUT the weird part is if I unplug the power cord and put it back, the console will start without pressing the power button and give that 3sec blod.
      UART shows error code 80800024 and nothing else. There are no cracks on the apu. No shorts on the board that I can find. All standby rails are present and all power on rail will show up for that 3second period. I've tested with two different psu and reflashed...
      08-19-2025, 11:44 AM
