lg 60ln5600-ub vertical lines no sound
  • huntertownsen
    • Jan 2017
    • 6
    • wa
    Hi thx for the forum 60ln5600-ub lg led tv, vertical black and white lines, no sound. unusual problem, it does have a few colored lines about a pixel width, every source change shows up differently on the screen.
    I believe the main board where the input, for audio video is out , I havent found anything on the web with a similiar problem, some of the sources are black and white lines just in the center 1/3 of the screen , black on the outside, some are all gray and black lines. thee is no sound at all , i have hooked up video and audio inputs the all the hdmi and rca jacks, the only difference i can see are a few small green blue and red lines when there is input. I thought tcon board but there is no sound, any help is much appreciated. thx again in advance rob
  • huntertownsen
    • Jan 2017
    • 6
    • wa
    Re: lg 60ln5600-ub vertical lines no sound
    Update i tested the power board and i have all the correct output voltages, when i used the nuetral bar as a negative for the meter, at both ends of the ribbon, i then tested the ground points. on one i had 0 resistance, on the other i had 1.3 k ohms??? suggestions would be appreciated thx rob
    • huntertownsen
      • Jan 2017
      • 6
      • wa
      Re: lg 60ln5600-ub vertical lines no sound PICS
      https://photos.google.com/shared
      I am new to forums, I am not sure how to post pics here. so far this is the best i can do lol.
      Any help with photo postings would be appreciated also , thx Rob
      • petehall347
        • Jan 2015
        • 4449
        • United Kingdom
        click on advanced then click on the paper clip .
        • huntertownsen
          • Jan 2017
          • 6
          • wa
          boy do i need to start wearing my glasses thx Rob
          • petehall347
            • Jan 2015
            • 4449
            • United Kingdom
            who is rob ?
            • huntertownsen
              • Jan 2017
              • 6
              • wa
              Sorry, I'm Rob
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                My money is on bad mainboard.
                Proud owner of dozens of broken TV's and many,many,many boards.
                Our website and passion:http://hollenhundshepherds.com/
                • arctor
                  samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                  by arctor
                  hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                  04-26-2025, 05:22 AM
                • Firentiosi
                  1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                  by Firentiosi
                  Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                  The issues are as follows: the...
                  11-27-2024, 12:33 AM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • Ancient1
                  Strange LG TV issue : Image vertical lines in black screen
                  by Ancient1
                  Hi
                  Asking for a friend.
                  I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                  but here its the opposite !
                  TV has new T-con = same issue
                  A missing panel voltage would have global effect
                  So , what should one do ? how can I find where the fault is ?
                  Thanks !...
                  02-05-2025, 03:37 PM
                • syedshueeb@gmail.com
                  Black spot and vertical lines on Sony KD-55x9300C
                  by syedshueeb@gmail.com
                  Can experts please share their opinion on this issue where i have a black spot and vertical lines all over the screen.
                  Is this fixable or needs a new panel?...
                  03-31-2023, 01:29 AM
