Eeprom dump thread!
This is a sticky topic.
  • totof
    • Feb 2017
    • 157
    • france
    #1301
    Re: Eeprom dump thread!
    Originally posted by lotas
    Try it, there are two dumps with different versions.
    Thank you very much lotas.
    In fact I can't fully test the binaries because I don't have the TV at home, I only have the electronic boards and the LED bars.
    The second binary (ue55mu6105_ic1604_II.bin) doesn't work, I don't even have the standby led.
    On the other hand, the first binary (ue55mu6105_ic1604.bin) seems to work: I have the standby LED, the tv turns on with the remote control and the backlighting turns on fine. On the other hand, to test the image, I will have to wait to return to my parents and it will only be in several weeks.
    I will post back to the forum at that time.
    • lotas
      • Jan 2016
      • 4554
      • Russia
      #1302
      Ok.
      • tehmatix
        • Nov 2012
        • 174
        Blaupunkt 32-147I-GB-5B-HBKUP-UK , tv bootloop, led red > blue > red >blue
        Desolder UF11 and use CH341 for reprogram. After , go to menu and Factory reset
        Firmware below
        • forall
          • Jul 2016
          • 6
          • spain
          #1304
          hi
          i need software for a a toshiba tv 49U5863DB
          tv stuck on logo.
          i think the main is vestel 17MB130S
          now i don't know the panel number.
          thanks
          • forall
            • Jul 2016
            • 6
            • spain
            #1305
            hi
            i need dump for a smart tv TD SYSTEMS, it stuck on logo, led flashing in red a green.
            the tv model is TD SYSTEMS K24DLH8FS
            the main is HK.T.RT2841P531
            thanks.
            • lotas
              • Jan 2016
              • 4554
              • Russia
              #1306
              Originally posted by forall
              hi
              tv stuck on logo.
              thanks
              There is on 49U6863DB, I don't know if it's suitable or not.
              https://www.vestel-spares.co.uk/inde...odel&order=ASC
              • Duranitron
                • Jul 2014
                • 544
                • Philippines
                #1307
                Need Help guys... Need Dump file for TCL LED 40D3000D
                mainboard number is ms36k tp.ms3663.pb772. Thanks in advance
                • lotas
                  • Jan 2016
                  • 4554
                  • Russia
                  #1308
                  the software in the dump is working, try the cropped one.
                  • Duranitron
                    • Jul 2014
                    • 544
                    • Philippines
                    #1309
                    Thanks very much..
                    findings: the moment you plug the power to the tv the standby led turns on.. power on button and remote control power button have no effect.
                    main power are present 50v and 12 volts. 3.3 volts present in the pin 8 of EEPROM 25Q64 . 1.2 volts present in the video ic. backlight good test with backlight tester. Test the 25Q64 ic with programmer test good data verification at 100%.
                    • simplytrini
                      • Jul 2011
                      • 73
                      Rca rtu 5540-d eeprom file
                      Hi folks how is everyone doing? Does any one have a Bin file for this model tv?
                      RTU5540-D DP.3458HB.815 RCA Main Board(3458HB.81518100401322). Thank in advance
                      • STE Tuxtla
                        • Sep 2022
                        • México
                        #1311
                        139 / 5.000
                        Resultados de traducción
                        Hello, I have a JVC model SI24H TV, model SI24H, board CV3553BL-U24, with problems in the eeprom (it is stuck on the red led), I upload the backup, thanks in advance.
                        • lotas
                          • Jan 2016
                          • 4554
                          • Russia
                          #1312
                          Originally posted by STE Tuxtla
                          139 / 5.000
                          • lotas
                            • Jan 2016
                            • 4554
                            • Russia
                            #1313
                            Re: Rca rtu 5540-d eeprom file
                            Post your DUMP here.
                            • STE Tuxtla
                              • Sep 2022
                              • México
                              #1314
                              Hello lotas, I tried the cropped version that you provided me, but it still has the same symptom (stuck on red led), any other ideas? Thank you for your answer.
                              • lotas
                                • Jan 2016
                                • 4554
                                • Russia
                                #1315
                                Replace with a new Spi flash, maybe the problem is not in the firmware.
                                • totof
                                  • Feb 2017
                                  • 157
                                  • france
                                  #1316
                                  I have my TV model UE50KU6070 which I am trying to repair.
                                  BN41-02528A / BN94-10800C motherboard.
                                  If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                  When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                  After one minute the consumption drops to 0W and the TV can turn on with the remote control but the screen remains black. All voltages on the motherboard are correct.
                                  The TV turns off with the remote control but you have to wait about 1 minute before restarting it again. Sometimes at startup the screen displays "Samsung Smart TV" for 1 second before going black.
                                  In fact, in addition to the black screen, it is as if the TV was extremely slow.
                                  The behavior is the same if I disconnect the two LVDS cables.
                                  Can everybody check if the SPI dump of my tv is correct ?
                                  • lotas
                                    • Jan 2016
                                    • 4554
                                    • Russia
                                    #1317
                                    Try it, just save all your dumps, 25Q80 is responsible for T-con.
                                    • totof
                                      • Feb 2017
                                      • 157
                                      • france
                                      #1318
                                      Thank you lotas, I will try this week end.
                                      Two questions :
                                      - Is it mandatory to flash the 3 chips ? (25Q40, 25Q80 and 24C512)
                                      - Is it mandatory to desolder the components to flash them or can this be done without desoldering them from the board ?
                                      • lotas
                                        • Jan 2016
                                        • 4554
                                        • Russia
                                        #1319
                                        Try all three at once, without soldering there may be errors when reading and writing, just save yours.
                                        • totof
                                          • Feb 2017
                                          • 157
                                          • france
                                          #1320
                                          I have saved the 3 chips but I have a problem for the 25Q32 on the panel bord because I cant write your 24C512.bin file
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
