Eeprom dump thread!
This is a sticky topic.
  • cheeky2
    • Dec 2012
    • 337
    • uk
    #1101
    Re: Eeprom dump thread!
    Originally posted by mallard729
    25l32063
    Your unlikely get any help when you haven't entered essential information from your TV.
    I suggest you also check your flash ic details as well!
    • mallard729
      • Dec 2021
      • 11
      • usa
      #1102
      thanks for the input is the ic the top line of the chip?
      as in mxic mx ? i guess board model would help as well, i was trying to copy other posts, but lots of these numbers and terms i am not too familiar with
      thanks again !
      • mallard729
        • Dec 2021
        • 11
        • usa
        #1103
        Vizio p65-c1
        main board # XFCB0QK038010X (seems like the p50 used same board)
        Need firmware dump
        ic chip
        MXIC MX
        25L3206E
        M-2I-12G
        3I365700A1 (I think hard to read)
        LI53476
        pick attached
        any other info needed?
        • mallard729
          • Dec 2021
          • 11
          • usa
          #1104
          i was able to pull this file off of the chip i thought was bad. if this file is intact/valid does that rule out my matronix ic 25L3206E, as the issue? the original issue is the vizio logo reboot loop after a frozen auto firmware update
          Seems like reflashing what i have downloaded for the ic would not accomplish anything, but i am very new to this, any help is welcomed
          • lotas
            • Jan 2016
            • 4554
            • Russia
            #1105
            I'm not familiar with Vizio TVs, but most likely you have a problem in another flash, this is emmc, where the software is located, you need to try to force the update via USB, but you need to know how to go through this procedure, if the flash EMMc starts to crumble (wear), then rather only replacement of the mainboard.
            https://support.vizio.com/s/article/...language=en_US
            It is necessary to ensure that when the TV is turned on to the socket, it must immediately pick up the update on USB (the files with the updates must strictly comply with the instructions, as written on their website).
            • mallard729
              • Dec 2021
              • 11
              • usa
              #1106
              thanks for the input, i tried the firmware via usb, but none of the buttons function on back of the tv, they did before this issue started.....
              so it is likely maybe i selected the wrong ic chip ?
              • lotas
                • Jan 2016
                • 4554
                • Russia
                #1107
                But you need to try to force it to pick up the firmware, maybe you need to hold down "OK" or "Power" or the same buttons on the TV with an inserted USB stick, and then apply power, try to change other USB sticks of the old model no more than 2Gb.
                • mallard729
                  • Dec 2021
                  • 11
                  • usa
                  #1108
                  i have tried for like 3 hours, about 4 different memory sticks, insert usb, plug in to outlet while holding down the buttons, makes no difference, i can leave the tv powered on in a boot loop and holding down power button does nothing , does not shutdown the tv, just stays in a boot loop.
                  can this device boot off a usb to try and flash firmware? i think it needs to be at the no signal screen ....
                  • mallard729
                    • Dec 2021
                    • 11
                    • usa
                    #1109
                    i got another 2gb flash drive and tried again, nothing works, i don't think these can boot off usb. pretty sure u gotta have the tv OS loaded ... thanks anyways
                    • Yanleb
                      • May 2017
                      • 101
                      Toshiba Seine Board PE0362 EEPROM Dump for 42LX177, 46LX177, 52LX177, 57LX177. Includes IC115 (39VF800A) and IC117 (K9F1208U0C).
                      Check this web page that explains how to look at the booting sequence using a serial port and a terminal:
                      http://www.benjammin.net/www/pages/t...a-42HL167.html
                      • HenryJ
                        • Oct 2006
                        • 54
                        #1111
                        Alpine iLX-F309 needed. At a loss on this one powers on never boots, service info not available to us mortals.
                        • Helikvar
                          • Jul 2018
                          • 68
                          Looking for eeprom dump for Rca rlded4633a-d TP.MS3393.PC821 .I have original eeprom dump but tv stays in standby.Tried a few other eeproms but picture is inverted when powered on.Tried flipping in service menu but image won't flip.
                          • lotas
                            • Jan 2016
                            • 4554
                            • Russia
                            #1113
                            Post your own, non-working dump, I'll try to fix it.
                            • dodysallam
                              • Jan 2022
                              • 7
                              • egypt
                              #1114
                              Pleas I want dump for seiki model se32hy27 main tp.ms3393.p85 think for help
                              • lotas
                                • Jan 2016
                                • 4554
                                • Russia
                                #1115
                                • dodysallam
                                  • Jan 2022
                                  • 7
                                  • egypt
                                  #1116
                                  Think you I want flash for tp.ms3393.p85 model SEIKI Se32hy27
                                  • lotas
                                    • Jan 2016
                                    • 4554
                                    • Russia
                                    #1117
                                    If the problem is in the firmware, then read the data (DUMP) from the spi flash and put it here and I will restore the firmware for you.
                                    • lotas
                                      • Jan 2016
                                      • 4554
                                      • Russia
                                      #1118
                                      What's the problem with TV?
                                      • dodysallam
                                        • Jan 2022
                                        • 7
                                        • egypt
                                        #1119
                                        Just only red led not working
                                        • lotas
                                          • Jan 2016
                                          • 4554
                                          • Russia
                                          #1120
                                          Do you have a programmer?
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
