Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
I celebrated too fast! when I turned the set off it would not come back
on same as original fault.Strange though when I reprogram the spi in situ it works again but when power is removed it wont come back on. the set appears fine when its running although the cpu is hot approx 72c I think its a cpu fault.or could it still be firmware ?.maybe just replace mainboard..any one seen this issue before ?
Thanks for reading.Comment
board on picture.
cv318hLast edited by ARGO; 03-14-2019, 03:13 PM.Comment
Re: I-JOY idi22spb 05 V2
Try original dump for eeprom+spiComment
I'm sorry but if you do not get details about TV, motherboard, panel, do not expect to get help.
It is valid for everyone.Comment
MODEL: b32fa173bk
PRODUCT CODE: BW32O173BBKPE421
MAINBOARD: T.MSD309.9b 10345
PANEL: LTA320AN12
TUNER: XDTT-6F1C/T1146Attached FilesComment
Bravo led32 bed11 main-hk.t.rda8501p538 spi 25q32
Bravo led32 bed11 main:hk.t.rda8501p538 spi 25q32Attached FilesComment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
Yesterday, 03:24 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... - Loading...
