Eeprom dump thread!
This is a sticky topic.
  • dani502017
    Banned
    • Sep 2017
    • 85
    #441
    Re: Eeprom dump thread!
    Originally posted by jellytot
    Looking for a firmware dump for a Toshiba 26EL933B. There is an update file
    on the toshiba site but requires a working tv to do the upgrade on. although its a Bin file and it looks ok at the beginning using HXD, but its about half the size..
    any ideas..? Thanks in advance..
    chasis,main,panel?
    • jellytot
      • Mar 2015
      • 42
      • Ireland
      #442
      Hi. dani502017. mainboard is: 32AV933_MAIN BD REV 1.02
      sticker info EU32AV933
      V1.00 P3
      WinbF544
      Slim Line TV. Can't see the Panel information its covered over by a Plate. would have to dismantle further.
      • dani502017
        Banned
        • Sep 2017
        • 85
        #443
        V1.00 P3
        WinbF544
        try
        • jellytot
          • Mar 2015
          • 42
          • Ireland
          #444
          dani502017! Your a gentleman and a scholar That worked like a charm.
          Thank you for your help
          Wow! you must have a great (large) library of files
          Thank you for your willingness to share.....
          • jellytot
            • Mar 2015
            • 42
            • Ireland
            #445
            I celebrated too fast! when I turned the set off it would not come back
            on same as original fault. Strange though when I reprogram the spi in situ it works again but when power is removed it wont come back on. the set appears fine when its running although the cpu is hot approx 72c I think its a cpu fault.or could it still be firmware ?.maybe just replace mainboard..any one seen this issue before ?
            Thanks for reading.
            • dani502017
              Banned
              • Sep 2017
              • 85
              #446
              Thanks for reading.
              Have you changed SPI memory too?
              • jellytot
                • Mar 2015
                • 42
                • Ireland
                #447
                Yes. I replaced the spi flash also tried reflowing the micro,also tried an upgrade using
                update file from Toshiba, still the same. each time if I reflash it works until power off
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8115
                  You better keep that programmer handy then!
                  • jellytot
                    • Mar 2015
                    • 42
                    • Ireland
                    #449
                    • ARGO
                      • Jul 2018
                      • 31
                      Originally posted by Unspun01
                      Can anyone upload a firmware for an RCA 32" LED TV?
                      Model: RLED3216A (Canada)
                      Mainboard: CV318H-X
                      EEPROM type: Winbond 25Q16CVSIG
                      EEPROM Location: U10
                      Panel: AU T315XW06 V.6
                      May be same or similar to Proscan PLED3216A
                      Spectre 42 inch LCD TV
                      board on picture.
                      cv318h
                      • vzekic
                        • May 2010
                        #451
                        Hi
                        I nead dump for Qadro 32af40
                        Tx
                        • hazar33
                          • Mar 2019
                          • türkiye
                          #452
                          Sn032dld12at022-sm dump anolog modul uydusuz v.0.5
                          sunny dump file
                          • tachiouine
                            • Nov 2018
                            • 32
                            • maroc
                            #453
                            I-JOY idi22spb 05 V2
                            pl dump HK-7050-CI-V4.1-B
                            .I-JOY idi22spb 05 V2
                            • dani502017
                              Banned
                              • Sep 2017
                              • 85
                              #454
                              Re: I-JOY idi22spb 05 V2
                              Try original dump for eeprom+spi
                              • dani502017
                                Banned
                                • Sep 2017
                                • 85
                                #455
                                I'm sorry but if you do not get details about TV, motherboard, panel, do not expect to get help.
                                It is valid for everyone.
                                • magnetepazzo
                                  • Feb 2017
                                  • 85
                                  • italy
                                  #456
                                  Hi someone have firmware for t.msd309.9b? Thanks
                                  • birdcomloso
                                    • Jun 2018
                                    • Thailand
                                    #457
                                    thanks you
                                    • Rajnhl
                                      • Oct 2018
                                      • 94
                                      • India
                                      #458
                                      MODEL: b32fa173bk
                                      PRODUCT CODE: BW32O173BBKPE421
                                      MAINBOARD: T.MSD309.9b 10345
                                      PANEL: LTA320AN12
                                      TUNER: XDTT-6F1C/T1146
                                      • salmad
                                        • May 2014
                                        • 8
                                        • maroc
                                        #459
                                        Hi someone have dump for Hisense 32h3e Main .Tp.ms3393.pb851
                                        • egypt
                                          • Mar 2019
                                          • 6
                                          • alxsandria
                                          #460
                                          Bravo led32 bed11 main-hk.t.rda8501p538 spi 25q32
                                          Bravo led32 bed11 main:hk.t.rda8501p538 spi 25q32
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
