Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
I celebrated too fast! when I turned the set off it would not come back
on same as original fault.
Strange though when I reprogram the spi in situ it works again but when power is removed it wont come back on. the set appears fine when its running although the cpu is hot approx 72c I think its a cpu fault.or could it still be firmware ?.maybe just replace mainboard..any one seen this issue before ?
Thanks for reading.Comment
Have you changed SPI memory too?I celebrated too fast! when I turned the set off it would not come back
Re: I-JOY idi22spb 05 V2
Try original dump for eeprom+spiAttached Filesif you find these attachements useful please consider making a small donation to the site
I'm sorry but if you do not get details about TV, motherboard, panel, do not expect to get help.
It is valid for everyone.Comment
MODEL: b32fa173bk
PRODUCT CODE: BW32O173BBKPE421
MAINBOARD: T.MSD309.9b 10345
PANEL: LTA320AN12
TUNER: XDTT-6F1C/T1146Attached Filesif you find these attachements useful please consider making a small donation to the site
Bravo led32 bed11 main-hk.t.rda8501p538 spi 25q32
Bravo led32 bed11 main:hk.t.rda8501p538 spi 25q32Attached Filesif you find these attachements useful please consider making a small donation to the site
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
- Loading...
That worked like a charm.
