LG 60ps80-UA
  • Eddiekaes
    • Jan 2017
    • 3
    LG 60ps80-UA
    Good day, I could not get any of my HDMI ports working and after troubleshooting I thought I would try to reset the HDMI ports. I got into the service menu ok, but I'm afraid I did something wrong once inside. My TV does start up but I get no picture whatsoever. The screen is on and dark gray. I'm hoping I didn't turn it into a brick. I Can't access any menu. I have a LG60ps80-ua. Any help in resetting it?
    Thank you - Eddie
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 60ps80-UA
    Run test patterns use bcn to find out how.
    • Eddiekaes
      • Jan 2017
      • 3
      Re: LG 60ps80-UA
      Sorry for my ignorance. What is bcn and how would I run it?
      Thanks,
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: LG 60ps80-UA
        Bad caps.net-bcn also use the search feature or google on how to run Kg Pdp test patterns. Seems like your Mb is failed probably solder issue on the mainboard.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Re: LG 60ps80-UA
          https://www.badcaps.net/forum/showth...+test+patterns
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • Retro140
            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
            by Retro140
            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
            06-18-2023, 06:13 PM
          • Ierwin
            Philips 58PUS7805 Menu working but no/weird picture from video sources
            by Ierwin
            I got a 58pus7805 that shows some weird behavior.
            The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
            However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
            I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
            I managed to install the latest official firmware by holding the control button while plugging...
            03-10-2024, 12:50 PM
          • vf fa
            EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
            by vf fa
            Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
            I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
            So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
            01-31-2024, 01:40 PM
