LG 60ps80-UA
  • Eddiekaes
    • Jan 2017
    LG 60ps80-UA
    Good day, I could not get any of my HDMI ports working and after troubleshooting I thought I would try to reset the HDMI ports. I got into the service menu ok, but I'm afraid I did something wrong once inside. My TV does start up but I get no picture whatsoever. The screen is on and dark gray. I'm hoping I didn't turn it into a brick. I Can't access any menu. I have a LG60ps80-ua. Any help in resetting it?
    Thank you - Eddie
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 60ps80-UA
    Run test patterns use bcn to find out how.
    • Eddiekaes
      • Jan 2017
      Re: LG 60ps80-UA
      Sorry for my ignorance. What is bcn and how would I run it?
      Thanks,
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: LG 60ps80-UA
        Bad caps.net-bcn also use the search feature or google on how to run Kg Pdp test patterns. Seems like your Mb is failed probably solder issue on the mainboard.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Re: LG 60ps80-UA
          https://www.badcaps.net/forum/showth...+test+patterns
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • Retro140
            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
            by Retro140
            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
            06-18-2023, 06:13 PM
          • Ierwin
            Philips 58PUS7805 Menu working but no/weird picture from video sources
            by Ierwin
            I got a 58pus7805 that shows some weird behavior.
            The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
            However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
            I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
            I managed to install the latest official firmware by holding the control button while plugging...
            03-10-2024, 12:50 PM
          • vf fa
            EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
            by vf fa
            Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
            I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
            So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
            01-31-2024, 01:40 PM
          • spleenharvester
            GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
            by spleenharvester
            I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
            07-08-2025, 06:02 PM
