Toshiba 19BL502B replaced diode worked, now not working
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Toshiba 19BL502B replaced diode worked, now not working
    Originally posted by dick_barton
    You appear to have an inverter fault. Will be interested in what other's think.
    I suspect that when the voltage was rising to 33V it may well have damaged some of the components / IC's on that circuit board by going over voltage.
    +1 or could of been the diodes shorting which killed the Led driver.
    • David-OLW
      • Jan 2017
      • 26
      • United Kingdom
      Which Board has the LED Driver and inverter on then?. Where are the connections to the LED's? the main board only has a ribbon type cable from it.
      Thanks David.
        https://www.badcaps.net/forum/attach...1&d=1484649140
        Small green board on the top right is the LED driver board, this not CCFL backlights system so there is no Inverter board.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          +1 Stand corrected.
          So possible led driver board or led fault.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            There's a fuse marked in red box which would be worth checking. Also check all the 0 ohms resistors.
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              for some reason i thought this was a ccfl set too but as the others say check the fuse and the zero ohm resistors then we can advise further
                Since that LED driver has boost converter, so check the DC in at the fuse and DC out to the LED when BL-ON is present.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  in post 14 bl on voltage 0.23v shouldnt that be higher? is it the led driver board that turns this command on higher voltage?
                  • David-OLW
                    • Jan 2017
                    • 26
                    • United Kingdom
                    #29
                    Many Thanks for your help.
                    I have 27.2 volts both sides of the fuse. Have checked all zero resistors with multi meter and have continuity across them.
                    David
                      The LED driver circuit needs the BL-ON signal to turn on the Boost converter circuit.
                      That Voltage should toggle HIGH when TV is turned ON, I expect >2.5VDC if it is active high to turn on the circuit.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #31
                        when i asked him to test it in post 14 thats the voltage he got with the set turned on hence i thought it maybe a mainboard issue?
                        • David-OLW
                          • Jan 2017
                          • 26
                          • United Kingdom
                          #32
                          Pin 3 BKL_ON/Off when ON is 3.04 volts
                          Pin 4 PWM_DIM when ON is 0.23 volts
                          David
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            sorry i got messed up with pin numbers so that voltage is fine , not sure though what the pwm-dim should read?
                              David
                              I expect the Dimming control line to be higher than that.
                              BL-ON is OK @3.04V.
                              Put the black probe on the chassis, red probe on the DIM then turn the TV on to see if DIM VDC jumps up at all.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #35
                                in the other thread dim is 2.3 v
                                  I will wait see what he gets on the DIM line when TV is first turned on, the 0.23V he is getting right now is too low.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #37
                                    what is dim line purpose?
                                      To adjust the backlights level.
                                      Typical dimming control:
                                      Analog dimming: 1Vdc = min backlights, 5V = max backlights
                                      PWM dimming: 10% pulse width = min, 90 % pulse width =max.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        thanks i was just reading up on pwm-dim theres so much to learn in regards to repairing electronics
                                        • David-OLW
                                          • Jan 2017
                                          • 26
                                          • United Kingdom
                                          #40
                                          BL-ON is OK @3.04V.
                                          In standby it is zero on turning on it goes up to 3.09 volts then slowly reduces (over about 10 seconds) to 0.23, have repeated several times.
                                          Thanks David
                                            09-06-2024, 05:27 AM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                            09-06-2024, 05:59 AM
