Toshiba 19BL502B replaced diode worked, now not working
  • David-OLW
    • Jan 2017
    • 26
    • United Kingdom
    Toshiba 19BL502B Main Board 23039106 PSU Vestel 17pw05-3 150411/23020632
    Was Dead, found D709 centre diode shorted, removed put on briefly on and worked ok. Replaced all 3 diodes, RS did not have UF5408 in stock so used G1751. Worked ok for couple of days, then not working green light on but no picture. There was a smell of burning. Found the 3 diodes very hot and 2 Capacitors were warm C729, C730. Replaced the 3 16 volt 1000ยต capacitors C729, C730, C731, but still not working, goes from standby to ON green steady light but no picture.
    With Main Board disconnected Volts on PSU 11.5 DC Volts/24 DC volts, with Main Board connected in standby volts on PSU 8.69 DC Volts/20.8 DC Volts, turning it on 11.8/33 DC volts, and the 3 diode get very hot. To me this would suggest the Main Board is drawing a lot of current, although the 12v DC is low, and why does the 24 volts go up to 33 volts.
    Any advice would be greatly appreciated.
    Thanks David.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Toshiba 19BL502B replaced diode worked, now not working
    The diodes do not looks like suitable replacements. The UF are ultra fast switching diodes and the G is a general purpose diode, You need to replace with suitable ultrafast diodes.
    Also check and or replace C734, C735
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      As the Psu gives 12v and 24 it is wokring, however the mb should not be causing it to over heat meaning its faulty likely tripping psu into protect mode. If you have a 12v Psu put it into the mb and see what smokes or use a dmm to see if you can find anything thats SC but this can take time. Also Psu raises to 24v for the Led driver, tried disconncting that to see if works.
      • vinceroger69
        • Mar 2012
        • 6714
        not the cheapest of places but delivery is quick as used this seller myself
        http://www.ebay.co.uk/itm/Vishay-UF5...UAAOSwcLxYC9wJ
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          farnell have them
          cpc have them as well
          if you speak to rs nicely they might get some flown in for you .
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Also on these you can use UF5404 they will run at a good temp. Check ebay as well.
              +1, wrong type of replacement.
              • David-OLW
                • Jan 2017
                • 26
                • United Kingdom
                OK have replaced diodes with UF5408 and have replaced one capacitor C734/C735, there is only one position for a capacitor here, although marked C734 C735 see picture.
                I still have only 11.29 DC volts and 23.89 dc volts but the diodes are not getting hot now, green on light comes on ok but still no picture.
                How do I now trace the fault.
                Thanks for all your help.
                David.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Led driver test.
                  • David-OLW
                    • Jan 2017
                    • 26
                    • United Kingdom
                    Originally posted by ReeceyBurger123
                    Led driver test.
                    How do I do That?
                    David
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Do you have stby_5V on pin 11 of PL703. You mention 12V & 24V but not 5V
                      • David-OLW
                        • Jan 2017
                        • 26
                        • United Kingdom
                        Yes the red standby light comes and then using remote turns on to give green steady light.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          on plug pl706 on pin 4 what voltage do you get on there with the set turned on as its for the bk lights
                          • David-OLW
                            • Jan 2017
                            • 26
                            • United Kingdom
                            On Pin 4 I have 0.23 volts, I am only measuring this with a multi meter, if it is PWM should I look at it the scope, should this be higher.
                            On the Diagram the only other place PWM_DIM is shown is on the Pin !3 on Main Board connector, does this signal come from the main Board.
                            Pin 1 and 2 27 volts
                            Pin 3 3.04 volts
                            Pin 4 0.23 volts
                            Pin 5 and 6 Ground
                            Thanks for your help
                            David
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              that seems low to me for a back light command voltage i wonder if you have a mainboard issue?
                              Edit just found this thread
                              this toshiba thread may help his back light voltage was 2.3 volts so maybe you do have a bad mainboard
                              https://www.badcaps.net/forum/showth...estel+17pw05-3
                              • David-OLW
                                • Jan 2017
                                • 26
                                • United Kingdom
                                Yes I had read that thread.
                                Is there any where I can get the schematic diagram for the Main Board 23039106? Anyone know what components could be faulty. Is there any way to apply a voltage to Pin 4 on T-Con to check Backlight?
                                Thanks David
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  im not 100% sure myself so i will let a more experienced member advise you. mainboard schematics are very hard to find a lot of the time there not available at all
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Using a bright light shine it at an angle on the screen while switching the menu on and off using your remote and see if it can be seen on the screen.
                                    • David-OLW
                                      • Jan 2017
                                      • 26
                                      • United Kingdom
                                      Yes using a bright light I can see the Menu.
                                      David
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        You appear to have an inverter fault. Will be interested in what other's think.
                                        I suspect that when the voltage was rising to 33V it may well have damaged some of the components / IC's on that circuit board by going over voltage.
                                          09-06-2024, 05:27 AM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                          09-06-2024, 05:59 AM
