42" LG Plasma won't turn on
  • neutron561
    • Jan 2017
    • 21
    I thought I could fix this TV for an elderly friend because I have a sorder sucker and changed caps in my own set before. Maybe not! She says the set was fine last time she turned it on, then the next day would not turn on.
    Product Code: 42PA4500-UM.AUSLLHR a LG 42” Plasma TV
    S/N: 208RMSSAL382
    Mfg.: August 2012
    Symptoms:
    Set dead, Won't turn on and NO click.
    Standby LED is on red
    No response when power button is pressed (I don't have the remote)
    With back taken off:
    5.25 volts DC on Standby terminal on Power Board. Upwards of 200 volts DC at other points such as SUS boards. Other lower DC voltages at logic board. I may be wrong but not leaning toward the power board.
    No swollen caps identified.
    There is a solid Red LED on the Main Logic Board (p/n 42PA4500-UM(1.1))
    A Green LED on the Control Board is flashing the sequence -.-.- pause & repeat.
    Is the Green LED a trouble code that will identify which board in trouble?
    Power goes from power board to the ZSUS board, then another wire harness from the ZSUS board to the YSUS board.
    Does anyone have knowledge of Blink Codes that will help me identify which board I need? What does this code tell you?
    Where is a starting point to troubleshoot and save this TV from the landfill? I don't want to start replacing boards without a good idea as to what the issue is.
    Thanks for any help
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: 42" LG Plasma won't turn on
    What are the voltages on P6 & P7?
    • neutron561
      • Jan 2017
      • 21
      If I am at the right pins, 5.25 vdc on each. Is that the plug on the power board going to the Main Logic board?
      • neutron561
        • Jan 2017
        • 21
        I think I was on the wrong place. P6 = 55.2 P7 = 5.24
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          P6 has 15 pins with the expected voltages written on the pcb board just above the connector and also what voltages are on the other connector with 7 pins
          • dskall
            • Oct 2016
            • 2905
            • usa
            I am no expert, so for what it's worth. I believe the green light is what they call a heartbeat light. It should blink once a second if healthy and once every 3 seconds if there is a problem. I have played with a few plasmas and every one had a problem on the left side. ysus and or buffer board. Look at your buffer chips far left green board. See if any show damage. Besides this great forum youtube is also good source. You might want to look up how to check buffer boards for shorts. Hope this helps some.
            • neutron561
              • Jan 2017
              • 21
              Got it. First, Thank you very much for the help.
              Tomorrow I will have to fashion something to connect my meter lead to P6 in the 15 pin area without shorting something.
              For P7: pin 1 & 2 = 205 vdc, pin 3 & 4 ground, pin 5 = 55.2 vdc, pin 6 = 5.24 vdc
              • neutron561
                • Jan 2017
                • 21
                Thanks dskall. That makes sense.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Hang on where is the heatsink for the Xbuffer gone on the bottom of the panel ?
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    With no click when you hit power button you might want to check for voltage change at your button connector when you press power button.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      +1
                      I believe from what I have read that you will damage the Xbuffer boards if you run the set without the heaksink in place
                      At the top of the panel there's a sticker giving voltages. Can you post an image of the sticker.
                      • neutron561
                        • Jan 2017
                        • 21
                        OK Dick, here's todays readings for P6: (all volts DC)
                        1. 55.2 vdc
                        2. 55.2 vdc
                        3. 55.2 vdc
                        4. .016
                        5. .016
                        6. 17.96
                        7. 17.97
                        8. 0 GND
                        9. 0 GND
                        10. 3.29
                        11. 1.59
                        12. 1.49
                        13. .043
                        14. .021
                        15. 5.23 vdc
                        P7:
                        1. 205
                        2. 205
                        3. Ground
                        4. Ground
                        5. 55.2
                        6. 5.24
                        NOTE: Set is outside where its 45-50 degrees. Green LED sequence has changed to ….- then after a while changer to …--
                        Dskall: I used a magnifying glass and can't identify any damage to chips or components.
                        • neutron561
                          • Jan 2017
                          • 21
                          Reecey: That is a HeatSink? I have it off to try to get access to the module that has the 8 buttons. (no access yet)
                          Dskall: The wire from the button module to the main board has 1 blue wire and 7 gray. The blue has 3.2ish volts and doesn't seem to change when ON button depressed. pin 2 is 0 v and doesn't seem to change when ON button depressed. Other gray wires are 0 or 3ish v. I was originally leaning toward an open power button.
                          • neutron561
                            • Jan 2017
                            • 21
                            Any tips on how to separate the plastic bezel from the glass screen without breaking anything?
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              Don't know what all proper voltages should be on each pin. Appears though that you have VA VS voltages. You've checked fuses on X and Y sus boards. Far left and right side.
                              • neutron561
                                • Jan 2017
                                • 21
                                I think you are referring to the ZSUS and YSUS, correct? I do not see any fuses on those boards. On the ZSUS board, there is a printing called FS1 10A but it is just a jumper.
                                I only see 2 fuses on the whole set, one is 120VAC and the other has over 300VDC on it, both on the power board.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  c107 blue capacitor is thst just a black mark on the casing or a hole?
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Originally posted by neutron561
                                    OK Dick, here’s todays readings for P6: (all volts DC)
                                    1. 55.2 vdc
                                    2. 55.2 vdc
                                    3. 55.2 vdc
                                    4. .016
                                    5. .016
                                    6. 17.96
                                    7. 17.97
                                    8. 0 GND
                                    9. 0 GND
                                    10. 3.29
                                    11. 1.59
                                    12. 1.49
                                    13. .043
                                    14. .021
                                    15. 5.23 vdc
                                    P7:
                                    1. 205
                                    2. 205
                                    3. Ground
                                    4. Ground
                                    5. 55.2
                                    6. 5.24
                                    Dskall: I used a magnifying glass and can’t identify any damage to chips or components.
                                    I see the 5V, Va and Vs are present and correct. Is the -203V and +125V present.?
                                    I'm not sure if P6 pins 11 - 14 voltages are correct so perhaps someone can advise.
                                    • neutron561
                                      • Jan 2017
                                      • 21
                                      Not a hole or burn. seems to be potting compound or some kind of dirt. It rubbed off.
                                      • neutron561
                                        • Jan 2017
                                        • 21
                                        Where do I look for the -203V and +125V? I remember some high negative voltage on the YSUS side this afternoon. Should there be voltage on the tops of the caps?
                                        • joliver82
                                          Sony XR-65A95L no power due to logic board issue
                                          by joliver82
                                          Hi guys!
                                          I'm trying to repair a TV that a friend gave me recently. Lightning struck next to his house and broke the TV apart from more electronic devices.
                                          First of all I've checked the power supply and it works as expected. I removed the logic board and shorted the 3.3v standby output to TCON_ON and POWER_ON and every voltage was generated as expected (12v and 25v for logic board and 32v for TCON).
                                          When trying to boot the TV normally (having the board connected), the TCON_ON signal is not generated from it which made me think there's some issue in the logic...
                                          Today, 04:57 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • korben_dallas
                                          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                          by korben_dallas
                                          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                          MY QUESTION:
                                          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                          02-14-2024, 12:23 AM
                                        • Stephen
                                          A2991 Logic Board issue, 20volts 0 amps help!
                                          by Stephen
                                          Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                          09-10-2025, 03:16 PM
                                        • Stephen
                                          A2991 logic board issue, 20volts 0 amps help!
                                          by Stephen
                                          09-10-2025, 03:15 PM
