I thought I could fix this TV for an elderly friend because I have a sorder sucker and changed caps in my own set before. Maybe not! She says the set was fine last time she turned it on, then the next day would not turn on.
Product Code: 42PA4500-UM.AUSLLHR a LG 42” Plasma TV
S/N: 208RMSSAL382
Mfg.: August 2012
Symptoms:
Set dead, Won't turn on and NO click.
Standby LED is on red
No response when power button is pressed (I don't have the remote)
With back taken off:
5.25 volts DC on Standby terminal on Power Board. Upwards of 200 volts DC at other points such as SUS boards. Other lower DC voltages at logic board. I may be wrong but not leaning toward the power board.
No swollen caps identified.
There is a solid Red LED on the Main Logic Board (p/n 42PA4500-UM(1.1))
A Green LED on the Control Board is flashing the sequence -.-.- pause & repeat.
Is the Green LED a trouble code that will identify which board in trouble?
Power goes from power board to the ZSUS board, then another wire harness from the ZSUS board to the YSUS board.
Does anyone have knowledge of Blink Codes that will help me identify which board I need? What does this code tell you?
Where is a starting point to troubleshoot and save this TV from the landfill? I don't want to start replacing boards without a good idea as to what the issue is.
Thanks for any help
S/N: 208RMSSAL382
Mfg.: August 2012
Symptoms:
Thanks for any help
