Sony KDL 48W600B Picture goes away, sound and backlights still work.
  • DesertRat
    • Oct 2013
    • 81
    Re: Sony KDL 48W600B Picture goes away, sound and backlights still work.
    Diah, I made a mistake in the OP title. It's a Sony KDL 48W600B, sorry about that. If you have the ability to change the title to match I'd appreciate it.
    Here's the link for it. (for anyone looking for the firmware download).
    https://esupport.sony.com/US/p/model...d#/downloadTab
    • DesertRat
      • Oct 2013
      • 81
      Diah, it's got the latest update already installed. When I go to install it, it tells me that "No newer version could be found" or something to that effect.
      And a big thank you to whomever changed to title of the thread to match the correct model for me. I'm sorry about the confusion this may have caused. I had the wrong number (40W...) on my mind when I started the thread.
      • CyberPhoenix
        Issue with picture quality of Sony bravia TV
        by CyberPhoenix
        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
        01-22-2024, 02:08 AM
      • noisykid
        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
        by noisykid
        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
        12-30-2024, 07:15 PM
      • tree5656
        diagnosing sony XBR-75X900H. NO PICTURE
        by tree5656
        This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
        11-09-2023, 04:55 PM
      • x_orange90_x
        Sony KD-75X750H no backlights
        by x_orange90_x
        I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
        Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
        07-16-2025, 07:49 PM
      • DXseekerMO
        TCL 55US57 backlights, no picture.
        by DXseekerMO
        So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
        The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
        Power Supply, main and T-CON board are working.
        Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
        Unhook FFC from left side...
        09-18-2021, 03:56 PM
