SONY KDL40EX503 - firmware / sourcing compatible main board
  • Beynon
    • 16
    Thanks to budm, dick_barton and ReeceyBurger123 in helping previously with mainboard diagnosis on this.
    Finding a compatible replacement main board with all the matching numbers is proving very difficult.
    Might it be a case of finding one close to it then updating firmware (which I've found on the sony eu site)?
    Here're the board and panel details:
    Main board: 1-881-636-23
    Sticker on main board: Y2008850J ; 158661; REV 106; SOFT 4085
    Panel: LTU400HF02
    Any assistance hugely appreciated.
  • Beynon
    • 16
    Re: SONY KDL40EX503 - firmware / sourcing compatible main board
    Does anyone have any thoughts on this?
    Could I use a main board that's close and update to the right firmware?
    eg.
    1-881-636-22 with matching model # and screen
    Or perhaps use a matching board with matching screen but one model up eg KDL-40EX710
    Would really appreciate any insights into sony board compatibility.
    Thanks in advance.
    • joby91
      SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
      by joby91
      I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
      I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
      I found one chat about firmware on ************** forum but i cannot read the comments.
      https://**************/forum/108-114100-1#880537
      09-04-2024, 01:34 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • cheeky2
      Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
      by cheeky2
      For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
      See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
      01-08-2024, 05:56 AM
    • AlexWhat
      SONY KDL-65w850c need latest firmware 6.827
      by AlexWhat
      In 2022 SONY did "Termination of TV Software Update" for this model.
      I did find older firmware but it can't be installed over newer one (rolled back)
      Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
      12-15-2024, 11:32 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
