LG 42LE5300-uc no power.
  • capwizard
    • Jun 2016
    • 1991
    LG 42LE5300-uc the one I tested LEDs screen worked good, relay click, AC current stop at 0.244A, nextstep jump 3.5v to power-on and DRV-on, screen lightup (pic3), this one T-con is in the screen, gonna be the motherboard, order one see what will happen, will update.
    LG 42LE5300 service manual:
    https://www.electronica-pt.com/esque...artdown/24431/
    PS: red mark is for easy to distinguish the pinouts. WHY, no use the resistors? because not necessary, no problems for me so far so good.
    PS: scree has been tested over here, took me less than 3 min.
    https://www.badcaps.net/forum/showthread.php?t=59327
    Re: LG 42LE5300-uc no power.
    https://www.badcaps.net/forum/showth...ted#post713400
    I always suggest to use resistor just in case the wrong connections are made like this one in post 108.
    • capwizard
      • Jun 2016
      • 1991
      Thank you, I think you just saved my life again, I did put 3.5v to DRV-on(pin4) missup with V-sync(pin5), lucky nothing happened, what happen the TV is 80", I promise I will use resistors from now on, no more lazybones.
      • capwizard
        • Jun 2016
        • 1991
        All men make mistakes, but only wise men learn from their mistakes....
        PS: red marker mark is for easy to distinguish the pinouts
        pic1-4 : 3.5v to power-on and 12v shows powersupply is on. R=6.8k
        pic5 : 3.5v to DRV-on R=6.8k the screen not come on because not enough current to drive DRV-on, change to 3.9k is the same result then I put a piece of wire it work..... WHAT.... you did that again...NO...NO.....this one is for laboratory experiment.....
        pic6-9 : change 12v to DRV-on R=6.8k screen come on.
        Reference:
        look at 4:00
        Why use Current Limiting Resistors | AddOhms #8
        https://www.youtube.com/watch?v=81zNcctopBI
        PS: At 4:30 use LM317 precision current limiter to drive LED is Budm's idea and basically the principle of "Poorman's LED TV Backlight Tester".
          I use the value between 330~1K Ohms range which will limit the shorted current to 5mA (5V supply with 1K, 15mA @ 330 Ohms), the current is very low so it will not damage the power supply if the jumping is done wrong.
          Most Command receiving signal pin has 1K resistor to feed the switched Transistor, see PS diagram fro typical set up..
          So if the Transistor has low Beta, then it may not be turned on hard enough if you use too high of the resistance. The resistor is used for protection in case it is connected to the wrong pin.
          • capwizard
            • Jun 2016
            • 1991
            "330~1K Ohms range which will limit the shorted current to 5mA (5V supply with 1K, 15mA @ 330 Ohms)"
            3.5v / 1000ohm = 3.5mA
            3.5v / 330ohm = 10.6mA
            PS: ive used 3.5v / 6.8kohm = 0.5 mA, YES, It is too low to drive DRV-on.
            I had learned one more lesson and tips.....
            Put A 330 Ohm between (3.5v , DRV-on) YES, screen lightup....
            PS: From here you know one of my secret is I never use current limit resistor before...
              Typical command receiver circuit.
              • capwizard
                • Jun 2016
                • 1991
                RB858 100ohm That is lower than I thought was! more and more low voltage applications, the current limit resistor will be lower than what we think is.
                Microchip announces a series of I2C EEPROM devices with the lowest operating voltage available on the market. The 24VLXX series of devices has an operating voltage down to 1.5V for both read and write operations, with a very low operating current of less than 400µA.
                  That Base resistor can be from 100 Ohms and up to 4.7K (sometime as high as 10K), it all depends on the Base to ground resistor (it will have around 0.6Vdc that Base-Gnd (Emitter) resistor of that circuit) and the Beta () of the Transistor to insure that the resistor will be fully on to allow enough current for the LED inside the OPTO.
                  • capwizard
                    • Jun 2016
                    • 1991
                    The transistor is the fundamental building block of all modern electronic devices, what happen that was A MOSFET or IGBT? Does they have β gain or lower GATE (Base ) resistor?
                    • angelos
                      LG LED TV Model 42LE5300 not switching on
                      by angelos
                      Hi Guys,
                      I have another unit that's beating me up here.
                      This set starts up and is in standby mode. Upon pressing the power button the set makes a relay clicking sound and then the on board "piezo speaker" which sounds when pressing any of the on board buttons starts making a long beeping sound. In the mean time the secondary voltages (those that should start up when pressing the power button) do not come up.
                      This is my findings so far.
                      1. When adding a 680 ohm resistor from +3.5V rail to the "Power ON" pin to force PSU secondary voltages...
                      02-09-2019, 07:03 AM
                    • anlu
                      Vestel Firmware - Toshiba 32W133DN
                      by anlu
                      Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                      Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                      02-04-2023, 12:59 AM
                    • nobitavanchoxuka
                      thinkpad e14 gen 3 no post no display
                      by nobitavanchoxuka
                      Went i pluging chager,power button flashing 4 times and lightup,keyboard backlight on and off(CAPSLK light off), fan working on 10second and off,cpu warm up, but the screen shows me nothing, no backlight. orange LED on(battery charging) I don't even see the lenovo logo.
                      I let the battery drain, and it didn't change anything.
                      I did try an external display, and there's no signal / black screen
                      I tried Win+Ctrl+Shift+B, did nothing, no beep
                      Can anyone tell me what happened to my laptop?
                      12-19-2022, 11:57 PM
                    • rudelito
                      Acer 5750 not turning on
                      by rudelito
                      Good day to all master
                      please help acer 5750 not turning on
                      and i do the voltage checking all voltage was present main rain 19v 3v and 5v
                      when i turning on the fan spinning and secondly its go off and i found out the
                      pch was turning hot
                      is ther any solution that maybe pch was shorting or they maybe another problem shorting please response
                      and what is the nextstep
                      07-08-2021, 08:55 PM
                    • lucky13
                      LG Power Board EAY60803201 (YP42LPBL) from 42LE5300
                      by lucky13
                      Hello all,
                      I followed this thread
                      https://www.badcaps.net/forum/showthread.php?t=57647
                      and it apparently was a capacitor C114 (per BUDM) that caused the problem.
                      Here is my situation:
                      ShopJimmy pix:
                      http://www.shopjimmy.com/lg-eay60803...upply-unit.htm
                      TV only has standby LED. I recll it also makes clicking sound when try to power up.
                      Found the power board only has standby voltage of 3.5v.
                      Removed power board from TV and jumpered...
                      11-05-2016, 03:52 PM
