Hi all, this is my first post so please go gentle on me!
I very recently picked up a Panasonic TH-46PZ81B (46" plasma 2008 vintage) with a known fault (10 blinks of the red power light after pressing the front power button) that I hope to repair so that I can give it to my sister. My sister is still using a 28" CRT in 2017! I'm hoping my sis gets a new TV and I get the satisfaction of bringing a plasma back to life!
I was hoping that the cause of this 10 blink SOS would be the TEA1611T chip on either the MC201 or MC301 located on the P(MAIN)-Board. This diagnosis seems to be wide spread across the internet and the chap selling the TV had even highlighted this as a likely cause. However, having purchased a couple of new IC's and fitted them along with new 1uF 0603 caps the fault remains unchanged.
At that point I did what I should have done in the first place which was to try to get hold of a service manual and to investigate the problem properly.
I've not been able to find a service manual for this specific TV but I have found one for the TH-46PZ81FV which seems to share the same P(MAIN)-Board (EXT2MM704MGH) and one for a TH-58PZ850AZ which seems to share similar PA and A-Boards. I've also found a couple of helpful threads on this very forum:
https://www.badcaps.net/forum/showpo...84&postcount=7
https://www.badcaps.net/forum/showthread.php?t=36706
11th Generation Full High Definition Plasma Display Training
With these resources in hand I set about trying to determine what was and wasn't working on the TV.
According to both service manuals the 10 blink SOS indicates one of the following errors: Sub 5V SOS; Main 3.3V SOS; DTV 9V SOS; or Tuner Power SOS.
What I've found so far:
Now I'm in a sort of 'chicken and egg' situation. I don't know whether there is a fault with IC1100 (seems unlikely, fingers crossed!) or if there is some other condition that is not being met preventing IC1100 aserting the TV_MAIN_ON line which in turn is preventing Main 3.3V being present causing the test to be failed.
One of the posts mentioned above talks about Vsus initially being present as well as the standby 15V. Vsus is controlled by MC201 on the P(MAIN)-Board and is definately not being generated. From measurements (although I've been struggling with this) it appears the optoisolator device acting as the ON/OFF switch for MC201 is intentionally driving MC201 into its OFF state at start-up (which suggests Vsus is not initially ment to be present, unless of cause this is a fault!).
The training document above (google docs) manages not to cover the PZ81 (even though I'm sure its from the same year as the PZ80 and PZ85) which is a shame because it does give a sequential work through of the power up sequence (page 13 seems the best sort of fit but doesn't mention Main 3.3V).
As you can probably tell I'm pretty well stuck (especially without the correct service manual).
Can anyone shed light on the correct sequence of rail power-ups for this unit and on 'what depends on what' for the TV to initially correctly enter the standby state?
Any advice welcomed.
- When the front power button is pressed the 15V F_STBY (15V standby supply originating from the P(MAIN)-Board) was being correctly generated (so MC301 was working!). The 15V generated does seem a little high, measured at 15.9V
- This in turn was feeding the PA-Board which generates both SUB 5V and DTV9V (SUB9V) measured from test points TPS5 and TPS9 on the PA-Board
- Also as long as the front power switch is left in the ON position (latched in) there is 5V present on the STBY5V line of P7(Pin 5)
- This would appear to leave Main 3.3V and 'Tuner Power' (I'm still not exactly sure what this one is)
- On the A-Board Sub 3.3V is present during the brief period after pressing the main TV power button before the unit shuts down
- 3.3V (STB3.3V) is present at connector A1
- The schematics I have show that Main 3.3V is simply a switched output from Sub 3.3V (Q5693 PMOS switch driven by a BJT which is controlled by IC1100)
- Main 3.3V is not present. The reason, IC1100 is not asserting the TV_MAIN_ON line
- I really need some experianced help!
and the other boards had come to life as well!
. With that plugged back in I tried turning on again and the TV when back to two relay clicks followed by a third. WTF! So I started turning the TV OFF and ON again in quick succession and the flippin TV only powered up and gave me a picture!
