SAMSUNG LA40A656 with vertical lines at startup
  • v0ltair3
    • Dec 2016
    • 11
    • Portugal
    Hi Everyone,
    I've just come across with this amazing site while trying to troubleshoot a recent problem that's happening with my TV set.
    From 2 days ago, whenever I turn on my TV I can't see a clear image, rather I see that the image is basically transformed into a bunch of vertical lines like below:
    Now if I try to loop the different sources for a few seconds (say 10 seconds), i.e. try to loop between the analog and digital sources, I eventually see a "normal screen" and its stays like that for as long as the TV is turn on, literally hours... this problem only happens again If I turn the TV off, wait a bit and then turn it on again.
    The only problem I see when I do this is that the image has some kind of "drag effect" in some type of images, like presenting the menu.
    I saw already some people complaining about this issue but I never saw the outcome... from what I've read in this forum already it seems to be related to the TCON board, but I was counting with the experience of the badcaps JEDIs to help me figure it out.
    Thanks a ton in advance for any guidance you might provide me.
  • Diah
    • Feb 2013
    • 6379
    Re: SAMSUNG LA40A656 with vertical lines at startup
    turn it off, and then on.to show this fault. don't play or touch any on TV or RC. leave it and calculate the time how long it will show normal after turning it on. don't touch any let see if it come back alone or not.. so give time to it
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      This is either a tabbonding issue on the panel or bad t-con. I hope its t-con....
      • v0ltair3
        • Dec 2016
        • 11
        • Portugal
        Hi Diah,
        first of all, thanks for the support, this is actually a nice angle..
        Indeed the TV "recovered" by it self after about 10 seconds... I was wondering it was related to the swap of the different sources but its apparently irrelevant.
        Does it somehow helps with the root cause analysis ?
        • Diah
          • Feb 2013
          • 6379
          its time now to open the cover and clean & reseat all cable and LVDS from MB to T-CON also the ribbon cable from T-CON to panel.. be cartful that LVDS and ribbon cable may dry out, and silver or gold pin are easily break from the its pad
          also do Factory reset . at this stage hope it will be normal.. if not then report here to go further electronic test - messurment
          • v0ltair3
            • Dec 2016
            • 11
            • Portugal
            If it's down to the panel it will be game over lets hope its not...
            • v0ltair3
              • Dec 2016
              • 11
              • Portugal
              Will do it in a few hours and revert back on this thread regardless of the outcome so other can take something out of it as well
              Thank you
              • cliff_hootarski
                • Jul 2006
                • 411
                Since this is a Samsung "A" model, could this be caused by a "C102" issue?
                • v0ltair3
                  • Dec 2016
                  • 11
                  • Portugal
                  I've made a cleanup of PSU, MB & T-CON board as well as reseat all cables including LVDS & ribbons that go out of the T-CON + factory reset, but the problem persists
                  After some time of the startup the TV goes "normal" as stated above and stays like that for hours to come until the next time turn off & on. (this time took almost a minute, but when "cold" it usually take a bit longer)
                  Below some pictures of the power supply & main board. I see at least one cap that needs replacement on the PSU and a weird liquid form stuff in the back of the MB (PCB Varnish ??).
                  • v0ltair3
                    • Dec 2016
                    • 11
                    • Portugal
                    H Cliff,
                    I am not aware of this C102 problem, can you kindly elaborate a bit more ?
                    Thank you
                    • cliff_hootarski
                      • Jul 2006
                      • 411
                      A lot of the "A" model Samsungs both plasma and LCDs have a well known problem of a certain capacitor C102 on the back side of the main board which causes all kinds of problems. However, I do not see this cap on your board.
                      • Diah
                        • Feb 2013
                        • 6379
                        the MB look had allot of dioxide, you need to use ethanol to clean it.
                        you need to narrow now which board make this noise at first start ( Cold state ) , use hair dryer to really warm up boards one by one then start the TV, to see which one will let it start normal. begin with MB.
                        • v0ltair3
                          • Dec 2016
                          • 11
                          • Portugal
                          I've mande a run on all 3 boards, PSU, MB and TCON.. at a first run it wasn't really deterministic, but I've then focus on the TCON and I was trying to turning off and on with or without heating the board to understand if there were some cause effect.
                          After a 3 or 4 runs were I was basically under the 20 seconds to a full working TV, it kind of get always OK and now startups correctly immediately. I've give it a good couple of hours of viewing and it was basically OK (it stopped working for a few seconds and the back to normal)
                          So I would say its around the TCON board, so it seems for now.
                          Is there any chance that the problem could be related with the ribbons that go towards panel itself ?
                          Thank everyone and wishing you all a happy new year!
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Have you changed the bulging cap on the power supply ?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Jeez,wait for Ali E to chime in he will know thr exact issue but might be a bit pissed you've not researched this chassis. Im busy today so will reply in a few days if he doesn't.
                              • Diah
                                • Feb 2013
                                • 6379
                                change this cap as marked on the photo attached..
                                • v0ltair3
                                  • Dec 2016
                                  • 11
                                  • Portugal
                                  Hi ReeceyBurger123,
                                  not my intension to piss off anyone but I didn't really found this exact problem, nevertheless I understand I will likely not be the first one with this issue
                                  I've try to do my homework and I did found a similar problem but the thread was missing the resolution...
                                  • v0ltair3
                                    • Dec 2016
                                    • 11
                                    • Portugal
                                    Hi Diah,
                                    I did change that cap already (it's a 470uF) but the problem is still there... I did another round heating the the T-CON and it started immediately so I'm almost sure the problem is focused there.
                                    I've noticed that some of the ribbon contacts are starting to peel off, I've position them carefully and it's now ok again but will eventually need to replace them as well.
                                    Below some closeups on the T-CON in case it help..
                                    Thank you
                                    • v0ltair3
                                      • Dec 2016
                                      • 11
                                      • Portugal
                                      Did anyone experience a similar problem ? I would purchase a new t-con board if I would be sure it's not planned related..
                                      Thank you
                                      • jackster
                                        Samsung Curved monitor C27FG70FQU with garbled vertical lines on startup
                                        by jackster
                                        I acquired a faulty curved Samsung C27FG70FQU which has the quite common problem of just showing weird vertical lines for a while after a cold boot.
                                        The issue is pretty bad with this one and it takes about 15 minutes before things normalize and a proper image is displayed. Once a proper image is shown it will work 100% until the display is shut down or put in standby for a while and allowed to cool for a bit.
                                        Even though this seems to be a quite common issue I haven't really found any information regarding what the root cause is and how to fix it. There is this video...
                                        02-13-2023, 01:56 PM
                                      • Stanley1843
                                        by Stanley1843
                                        06-29-2024, 11:54 AM
                                      • x_orange90_x
                                        Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                        by x_orange90_x
                                        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                        09-04-2023, 12:09 PM
                                        09-07-2024, 05:50 AM
                                      • Anonmis
                                        Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                                        by Anonmis
                                        Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                                        The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                                        12-01-2023, 04:31 PM
