Samsung Curved monitor C27FG70FQU with garbled vertical lines on startup
  • jackster
    • Nov 2021
    • 12
    • Finland
    I acquired a faulty curved Samsung C27FG70FQU which has the quite common problem of just showing weird vertical lines for a while after a cold boot.
    The issue is pretty bad with this one and it takes about 15 minutes before things normalize and a proper image is displayed. Once a proper image is shown it will work 100% until the display is shut down or put in standby for a while and allowed to cool for a bit.
    Even though this seems to be a quite common issue I haven't really found any information regarding what the root cause is and how to fix it. There is this video https://www.youtube.com/watch?v=AAZ9UlcAoNA where the problem is seemingly bypassed by removing a resistor which is in parallel with another one.
    I don't have the same board as in the video but I also noticed that blowing cool compressed air on a specific area on the PCB with some resistors will allow the picture to normalize for a second or so until it goes all distorted again. I tried replacing the resistors in question with lower value ones but it did not seem to make any real difference...
    Has anyone been able to properly diagnose and fix issues such as these?
    I've attached a picture with the resistors in question, I'm not quite sure yet if it is the lone resistor on the left or the group on the right which reacts to the cold spray. I've resoldered pretty much all of the components shown in the picture but it did not make any difference at all.
  • sbyseven
    • Mar 2016
    • 19
    • Spain
    Re: Samsung Curved monitor C27FG70FQU with garbled vertical lines on startup
    I had a monitor with that problem and it was because of the flex cable.
    • Stanley1843
      by Stanley1843
      06-29-2024, 11:54 AM
    • pni
      LG 49uf695v vertical coloured lines
      by pni
      Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
      11-14-2025, 03:15 AM
    • Falki
      Colorful LCD Vertical Lines on Samsung ue55es8090
      by Falki
      Hello there, ive recently found an older 55inch Samsung SmartTV.
      A similar issue has been posted as well but also with no actual response ...
      08-12-2025, 04:19 AM
    • visionbluedemon
      Help. Sony kd-65x85dj vertical lines
      by visionbluedemon
      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
      tried blocking LC lines too, but same results
      is it lcd panel issue or tcon board issue?...
      07-25-2025, 04:56 AM
    • gpo23
      Sony KDL-40V3000 - Vertical lines
      by gpo23
      i order a t-con because i had bad colors on my SONY KDL-40V3000 :
      With the new t-con the color are good but there are vertical lines on all the screen :
      I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
      Is there a way to fix the vertical lines on the new t-con ?
      Thank you for your help
      gpo23...
      10-04-2023, 09:11 AM
