i got this tv off the curb and am trying to get it working. I do not have much experience with plasma. I have verified that it has standby voltage. When tv is plugged in it will click and not show anything on the screen. If i disconnect the x I can get it to turn on and the samsung "boot sound" and nothing more it will stay on until i turn it off...is seems that the power for the xmain board goes through the y main board andi if i disconnect the y main board the tv will boot up...thelogic board does not turn on when i do this although it seems to try one time. Im assuming it is because the xmain board is disconected. VS and VSC voltages come up to normal then fall down as the control board turns off...but set stays on. I have tested VS VE VSC to ground and come back with megaohms so it doesnt seem shorted there. Mostly i have no idea where to go from here and do not have the cash to waste on the shotgun method. Could someone please give me a direction on here to go?
PN50B400P3DXZA clicks will not power on
Tags: None
Re: PN50B400P3DXZA clicks will not power on
Try replacing the blue cap next to the transformer on the power supply -
I cant bitch too much you attempted diagnoses. Maybe try using google and badcaps.net and check for how to find short circuits on plasma sustain boards in your case sounds like Ysus and Xsus could be short.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by phuzzydayFor masochists who want to see some of the crap that I have been through already... (Truly optional now though, all those trees were barked up for no reason.)
https://www.badcaps.net/forum/troubl...klight-circuit
I started a new thread to get a fresher look at things, even with eyes that looked before. It's different now!
So I got this on Facebook for $66US, blank screen. Just reseated all... - Loading...
