LG 50PK550 clicking - plasma newbie
  • jason424
    • Dec 2015
    • 187
    I have used these forums previously to help troubleshoot and repair capacitors/replace boards on LCD sets, however just was asked to look at my first plasma. I've done some reading about the differences in boards but the testing of the voltages/y vs. z boards confuses me.
    The TV clicks when trying to power on. The screen will flash gray a couple times then the set shuts down. I've unplugged both y and z boards and turned on the TV to only exhibit the same behavior. I've checked all capacitors for failure and there is none visible. I've checked the 3 white resistors in the upper right of the board and they all measure 10.4 ohms stable. I have also removed the board to check for broken solder points and nothing jumped out at me there either.
    Beyond that I'm not sure what or how to check next. I do see the VA and VS test points but not sure how to test (from point to ground to test voltage?).
    Thank you in advance.
    Jason
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 50PK550 clicking - plasma newbie
    Photo of the underside of the board.
    • jason424
      • Dec 2015
      • 187
      Attached 4 quads of the board.
      EDIT: I just noticed these all rotated counter-clockwise before uploading.
      Thank you,
      Jason
      • Hamie
        • Apr 2014
        • 1383
        Test these resistors here:
        The ones that are not in parallel can be tested with your meter without removing them from the board.
        • jason424
          • Dec 2015
          • 187
          Wasn't positive the resistors you were referencing in the screenshot of my pic. I tested the 2 pins pointing to in the pic below, stable at .5
          Your mention of those that aren't in parallel don't need to be removed from board to be tested...does that mean that the 3 I tested (in the upper right of the board) should be removed to test correctly? I did not remove them when I tested at 10.4 each.
          • Hamie
            • Apr 2014
            • 1383
            No I'm talking about the smd resistors.
            the wirewound 10ohm resistors are fine.
            • jason424
              • Dec 2015
              • 187
              Ohming across those 11 surface mounts I get nothing. No change to the display.
              • Hamie
                • Apr 2014
                • 1383
                ok so i have no idea what you're doing
                see pic, blue circle resistors are in parallel, red circle resistors are in series.
                • Hamie
                  • Apr 2014
                  • 1383
                  ok now put meter in ohm, and check this resistor. put black probe where ive put the black dot and red on the other.
                  post results.
                  • jason424
                    • Dec 2015
                    • 187
                    OK, sorry I misunderstood.
                    I set my meter to 20k and get nothing when testing. I checked all 5 (R103-R107) and get nothing on all of them.
                    • Hamie
                      • Apr 2014
                      • 1383
                      They are all over 100k
                      • jason424
                        • Dec 2015
                        • 187
                        R107: 96.8
                        R106: 140.6
                        R105: 140.5
                        R104: 199.3 then changed to nothing
                        R103: 199.0 then changed to nothing
                        • steviewonder
                          • Dec 2013
                          • 183
                          • england
                          Resolder the lot- A very common problem..the solder cracks-not visible to the eye.
                          • jason424
                            • Dec 2015
                            • 187
                            As in just those 5, or the whole board?
                            • steviewonder
                              • Dec 2013
                              • 183
                              • england
                              Just those five, If you look closely there's another chain of five nearby,resolder that chain too !
                              • jason424
                                • Dec 2015
                                • 187
                                Resoldered all of those and still the same. As soon as I plug in it clicks on, 2 gray flashes of screen and then clicks off.
                                • Hamie
                                  • Apr 2014
                                  • 1383
                                  Can you jump the power supply on without the mainboard.
                                  RL-ON jumped to any 5v
                                  • steviewonder
                                    • Dec 2013
                                    • 183
                                    • england
                                    Well,the only other thing i can think of there now is failure of IC301,In view the 10 ohm resistors are fine (the most common failure to cause this issue),Also check the diode nearby,it's connected in parallel with a very low ohm resistor-measuring in-circuit may look like it's shorted-remove and check the diode,the board reference escapes me on that one,but you will spot it.
                                    • steviewonder
                                      • Dec 2013
                                      • 183
                                      • england
                                      Diode near ic301,that is..
                                      • jason424
                                        • Dec 2015
                                        • 187
                                        I don't get anything when I run a jumper wire from RL ON to one of the 5.1V.
                                        • bffargo
                                          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                          by bffargo
                                          LG 60PB66550 NOV 2014
                                          PSU: EAY63168603
                                          PCB: EAX65359531 2013.11.01 Rev:1.0
                                          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                          Symptom:
                                          While watching, just went black and started clicking relay every few seconds.
                                          Initial diagnosis:
                                          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                          Deeper diagnosis:
                                          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                          09-09-2022, 07:34 PM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • novak2
                                          Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                                          by novak2
                                          Hello there,
                                          I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                                          The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                                          From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                                          Thanks in advance.
                                          09-25-2020, 02:34 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
